Whats this Green wire go to?
El Duderino
That's a broken O2 sensor connector
There are those who call me... Tim '83 911 SC 3.0 coupe (NA) You can't buy happiness, but you can buy car parts which is kind of the same thing. |
And the heater plugin is right above it.
Bruce |
Looks like its part of the wiring harness. Guess Ill just have do do the best I can. Was working fine when I had to remove engine to fix head stud...
Thanks Guys.
Be careful if you try fixing that wire, it's a shielded wire, a center conductor with a outer shield. DO NOT accidentally solder or allow the shield and the center conductor to touch each other! Had a car that had this wire repaired and they soldered the shield to the center wire! Took 2 days to figure out why that engine kept running rich!
Sal 1984 911 Carrera Cab M491 (Factory Wide Body) 1975 911S Targa (SOLD) 1964 356SC (SOLD) 1987 Ford Mustang LX 5.0 Convertible |
El Duderino
Louie85 is a member here that makes a replacement kit for the O2 sensor. Not 100% sure it is the same on the '84-'89 cars but you might check with him.
