speedometer
Hey guys
I am working on a 911 Porsche SC and the speedo is not working. how do I check it , the sending unit in rear end , the wiring etc. Thanks guys |
speedometer
an addition to my question,What I am asking is how do I find out if the speed sincer is bad on the ring gear are if a wire is bad or if the speedometer it self is bad
Don't know the year but normally a gear which is made out of plastic brakes inside the speedo - I would bet on that
Ernie |
speedometer
its a 1980 SC and what do I look for when I connect a meter to the wire that comes from the sensor is it ohms or dc or ac or what
targa80 thanks so if I take a volt meter and check the voltage on the connection between the seats where the sensor connects to the Brown/red wire and get 12 volt pulsing then this tells me that the sensor is good and the wire is good and the only thing it could be is the speedometer. Am I right
Thanks in advance |
Just to be clear, the car would have to be in gear and the wheels turning in order for the sensor to be making/breaking the ground connection. The voltmeter should be varying between 12volts and 0volts. The variation should increase as the wheels turn faster.
targa80
Thanks so much
Henry,
Do you remember where did you get your gears? Quote:
I have a brand new gear in the package that I bought for my 1977 911 for $20 shipped if you are interested.
Rnln,
If only your trip meter broke, your odo will still rotate. This would be your gears. If step-motor, both will not work. Also, you have to get specific gears for your year speedo, but I do not think broken gears are your problem. |
Porsche 911 (1974-1989) - Gauges & Miscellaneous - Page 3 |
Thanks Pat, both of my trip and odo meters don't work anymore, speedometer is still working. According to Draco, it's the step motor :(
| All times are GMT -8. The time now is 08:59 PM. |
