Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Porsche Crest Cabrio top damage....OUCH!
This just happened yesterday. The right side of the main frame for the convertible top has cracked completely through with caused the vertical weather stripe rail to bend as well. 1988 Porsche 911 Cabriolet.
I've search the threads here and found several people have referred others to a company called dC Automotive, which I've looked into and hopefully they can help. But, are there any others out there? Or are they the only ones?
Also, since I'm on a limited budget and plan on doing this myself any advise or referrals is greatly appreciated.
Thanks,
Old 12-13-2015, 07:58 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Local surfer
patz's Avatar
Take it to a welder. They may be able to repair it.
Old 12-13-2015, 08:23 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Banned for Life
RSBob's Avatar
DC Automotive may have used pieces for sale or other auto- recyclers (formerly known as junk yards). Do a search on auto recyclers and list your part needed, probably the whole frame, and you will receive bids back. Good luck.
Rick S, '71 914 3.0, '82 911SC EFI, R Gruppe #309
Old 12-13-2015, 08:36 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
geoz's Avatar
Check first if you can find a spare.
I think mine was also welded at some point, not sure who can do that since these are alloy castings.
cheers
hg
1988 911 Cabrio
Old 12-13-2015, 12:32 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
Take it to a wheel repair shop. They weld alloys every day and have the right rods. Alum rods don't work
83 911 Targa, 64 356c Cab
87 911/930 backdate
78 sc tub FS. 84 euro 928 5 sp project FS
Old 12-13-2015, 12:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Thanks for the responses. I really don't want to have it welded...I will if that is the only way. But more importantly is "how to" removed and install this part? Do I need to dissemble the entire top? or just enough to get it out?...
Any good books or guides out there for convertible tops?
Or, anyone in the Los Angeles area that you would recommend to perform this work?...if I go that route.
Thanks again.
Old 12-13-2015, 01:38 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
gduke2010
gduke2010's Avatar
Should be easy to find a part at Dc Auto. My right side now broke several years ago. It pocket a hole through the top fabric. The reason why it broke was, the top was out of alignment, the motors
and cables old. That's probably what caused your part to break, being out of alignment putting stress on the part.
So, make sure everything is aligned and working before using your top. They're not easy to align and if not aligned with everything working, the bow can break. I just open and close mine manually and use the roller latches to lock
Old 12-13-2015, 07:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
BTDT.
Its not that hard to R&R the piece and have it welded. Replacement piece was hard to find or very $$$.
Broken Top Bow on 88 Cabriolet
1988 Cab
2004 TT Cab
Old 12-13-2015, 08:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
geoz's Avatar
There is a chapter on the top in the factory manual but I don't think it talks about replacing parts of the top. From memory it is pretty self-evident.
cheers
hg
1988 911 Cabrio
Old 12-13-2015, 08:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Most importantly is to find out why it broke and fix that as well. This was happening on the 964 and it was due to the nuts on the mechanism coming loose.
Several dismantlers available. DC is one LA Dismantlers is another... Do a google search on it.
Drive safe!
Wachuko
'83 911 SC - RSR Conversion - Part 1 - The discovery / RSR Conversion - Part 2 - The build
'91-964 Cabriolet Widebody / '02 996TT
Old 12-14-2015, 03:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Many had had this top bow issue and after they have their bow repaired they just make the top open and close manually so this doesn't happen again. Like someone else stated your top is out of alignment from a bad motor and or cables which is very pricey to have fixed.
Old 12-14-2015, 04:08 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Take it apart and weld it
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 12-14-2015, 04:20 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
Well...
I believe the general concenses is;
1) Figure out "why" is broke and fix that first.
2) It should be very straight forward and easy to remove and replace.
3) Have it welded.
4) and lastly...kinda related to the first point, most of what I'm seeing and reading is convert it to a "manual" top.
If I convert it to a manual top, can I just get away with removing the motors out of the system and keeping the automatic locks? Or do I need to completely covert it to manual locks as well?
Old 12-14-2015, 05:43 AM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Thanks for the LA reference.
Old 12-14-2015, 05:44 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Cars and Cappuccino
tdw28210's Avatar
LA Dismantlers guys have been cool to me. Good luck.
http://www.carsandcappuccino.com
http://www.facebook.com/carsandcappuccino
1987 Cherryrot G50 Coupe
1985 Prussian Blau M491 Targa - 1 of 65 in the US
1977 Mexico Blue flared, 3.2, back date, sunroof-delete Coupe - in process.
Old 12-14-2015, 05:45 AM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
wayne robson's Avatar
Hi DeltaBravo, just in case this helps you,for sale on ebay,but i am sorry i
am not good on computor i can not drag these from ebay, take alook
these are the item numbers.
-----181957308700----252188849772----370840285550---231119880710
something here may help,can get my wife to paste these and other parts in 8 hours as it is
1.00am here now.If you ever find something at --Specalized german in Rancho Cordova
By Sacramento i have a friend that could inspect them for you. regards Wayne, Australia.
Old 12-14-2015, 06:55 AM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
I had a similar issue with my power top. Main Bow broke. I have since disconnected the power top, the locks still work and just open it manually. From what I was able to find the part is really expensive upwards of $800-$1K. I was luck in that mine cracked but very cleanly and no other damage. This was a few years ago and I had planned to get it welded but taking it apart seemed a much bigger job than I expected. So far I am just carful when I open and close it and have had no issues. I figure when I need to replace the top I will fix it unless something else happens.
1989 Cabriolet
1970 911E Sold
Old 12-14-2015, 07:40 AM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
wachuko's Avatar
Porsche Crest
Here my thread (on another forum) when I fixed mine... I caught it in time before it damaged the parts that broke on your car...
Cabrio Top Mechanism Problems - Rennlist Discussion Forums
Drive safe!
Wachuko
Old 12-14-2015, 10:01 AM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Is this as simple as disconnecting the transmissions, removing them entirely, or...?
I really wish my car had a manual top. One of the linked threads refers to "robust mechanism." I don't know, seems kinda Rube Goldberg to me. The original owner could have spent that $2,426 elsewhere on some other options!
Old 12-14-2015, 12:26 PM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
wachuko's Avatar
Follow the link I provided. As simple as loosening the middle bolt in each transmission...but you still need to make sure that the bolts holding the transmissions in place need to be tight. The manual operation just avoids the electric motors from damaging the top. If everything is not properly tight you can still break it opening the top manually
Drive safe!
Wachuko
Old 12-14-2015, 12:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #20 (permalink)
Tags
1988` , 911 , cabriolet , convertible , folding top
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
