LinkBack Thread Tools Rating: Thread Rating: 4 votes, 4.75 average.
Cars and Cappuccino
tdw28210's Avatar
More mundane, but critical work. We sunk the nut-serts into the car so that we could attach our custom quarter-bumper bracket. The bracket is channeled on the end to allow for adjustment, but really sturdy with grade 8 bolts and the stainless nut-serts.
http://www.carsandcappuccino.com
1987 Cherryrot G50 Coupe
1985 Prussian Blau M491 Targa - 1 of 65 in the US
1977 Mexico Blue flared, 3.2, back date, sunroof-delete Coupe - in process.
1972 Black T coupe to Longhood Turbo R5 tribute car (someday)
Old 12-22-2015, 08:11 PM
Cars and Cappuccino
tdw28210's Avatar
After much fitting, grinding, massaging the rear flares are on. Bonded to the car with 3M 08219 bonding agent and a bunch of screws. The car will cure and then be flipped and reinforced on the underside too.
Old 12-27-2015, 06:16 PM
Cars and Cappuccino
tdw28210's Avatar
the motivation...
Old 12-27-2015, 06:24 PM
Cars and Cappuccino
tdw28210's Avatar
And even more mundane rear end fabrication. Really want the bumper to body seal to be correct/even. It seems like the flange under the light box stopped too early and would require glue to hold the seal in place. So we "improved" it by fabricating a continuous flange that will hold the seal all the way to the bumper guard. The thin metal is not easy to weld, Had to tack and grind it several times as it kept blowing out.
Looks good when completed around midnight lat night.
Old 12-29-2015, 06:17 AM
Cars and Cappuccino
tdw28210's Avatar
So we finished fabbing the rear bumper and rear flares today. The flares will be held in place by a modified version of the stock bumper supports that thread through the engine compartment and the bumper extensions will stay attached to the flares via stainless nutserts and bolts.
We managed to get the car out of the garage (much rain here lately) in order to clean it out and turn the car arround. The wife (many thanks) managed to score two heavy duty drill press stands at Goodwill for $7.00 each just yesterday. They were the PERFECT height to support the car as our rear jack stands we had modified were a little too tall and would have required another cut and weld job.
We did some rough fitting of the front pieces including the metal hood. She is starting to look like a car now. Very happy.
Old 12-29-2015, 08:27 PM
very nice!! are you in charlotte?
Old 12-29-2015, 08:32 PM
Cars and Cappuccino
tdw28210's Avatar
Yes, near SouthPark.
Old 12-29-2015, 08:37 PM
Nice fab work!
Old 12-29-2015, 08:41 PM
Cars and Cappuccino
tdw28210's Avatar
Originally Posted by fanaudical View Post
Nice fab work!
Thanks. Way more than I am showing. Too tired to type it all up.
Old 12-30-2015, 06:13 AM
Hopelessly Addicted
Porschephanatic's Avatar
Thumbs up
Looks Great!
'81 SC Targa
'86 944
'49 Ford F-3
'13 Yamaha FZ-1 (Adrenaline Machine)
Old 12-30-2015, 02:21 PM
Send a message via ICQ to Sebscst
You're flying through that.
83 944 ( R.I.P.)
78 911 st backdate (3 years and counting)
87 944
Old 12-30-2015, 03:54 PM
Pictures are better anyways when you get a chance to show!!
'79 930 turbo RoW - Oak Green Metallic - k27-7200 - Kokeln Intercooler - RarlyL8 headers/muffler - Leask WuR - Tial 46mm - Rebel racing sphericals front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Wevo engine mounts - Rebel racing transmission mounts
'99 4Runner Sr5
Old 12-30-2015, 04:04 PM
Cars and Cappuccino
tdw28210's Avatar
Off for the holidays, so I got the time....
Old 12-31-2015, 04:32 AM
Fixer's Avatar
Looking great Trent ! You two are really doing a professional job here.
I had to remake the passenger side taillight box too, what a PITA !
Then the 911R experts pointed out how Porsche ground away the taillight box for fiberglass R taillights fitment..
Matt Mariani, Philly Pa IG: matt_mariani_rsc
[B]1983 Super Carrera Coupe 'Mad Max'
1969 911E targa Crystal Blue / Black (selling)
1968 SWB 912 "Stinger 912R 1680 lbs
1977 911S coupe "Bandit" all original for now
Old 12-31-2015, 05:12 AM
Fixer's Avatar
Here's the 911R altered taillight box..
Old 12-31-2015, 05:26 AM
Cars and Cappuccino
tdw28210's Avatar
Ahh, that sucks. Grind time or do conventional lenses?
Old 12-31-2015, 08:07 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
Porsche Crest
Really!!?? After all the work you have done... go with what you want.. what is another several hours of modifying this??
Just busting your b*.... either way is going to look great.
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Old 12-31-2015, 08:11 AM
Cars and Cappuccino
tdw28210's Avatar
More fabrication
SO we've moved on to the front bumper installation/fabrication. First the good news - the front bumper had threaded studs already glassed in. The bad news (but expected) we needed to fabricate a pair of brackets. We took the same path as the rear and used steel to form brackets the will be screwed into stainless nutserts mounted into the tub.
Driver's side has more bend to compensate for the battery area.
Passenger side bracket.
Also went up to Exclusive Motorsports in Denver, NC to look at some roll cages. I think I am going with a "X" configuration in the rear that will likely mount through the firewall.
Really don't want to work around a permanently welded cage in the cabin area -especially since everything will need to be re-installed. I may try something a little unique in that I want to weld the rear leg portion in the engine area but with an extra mounting plate butting up to the firewall rather than a continuous tube into the cabin. Then in the cabin, use bolts everywhere including bolting the rear leg mounting plates to the mounting plates now on the opposite of the firewall. Still don't know if I will do that.
Regardless if I go all bolt-in or hybrid weld/bolt-in it should look similar to this, except the X will closer to the back glass.
Old 12-31-2015, 03:06 PM
flyn-hawn's Avatar
Smile
Looking really good!
Old 12-31-2015, 06:34 PM
Cars and Cappuccino
tdw28210's Avatar
Spent the last couple days fitting the doors and fenders. That actually went pretty well
We then moved on to the turn signals and horn grills. Now that was a PIA. This was the firs time in the project I was starting to regret going with fiberglass. The openings were full of extra glass that we tried to massage with a bunch if air tools.
After about two hours of that, they still were not fitting. So we decided to cut the underside and sides of the turn signal boxes away. Only after we did that did everything start to line up.
We are going to fabricate the removed areas out of metal to hold everything in place and reinforce the bumper tomorrow.
Old 01-02-2016, 02:26 PM
