-   -   Windshiled washer system- Simple Clean Solution (http://forums.pelicanparts.com/porsche-911-technical-forum/895142-windshiled-washer-system-simple-clean-solution.html)
impactbumper 12-15-2015 07:02 PM
The guy who owned my car before apparently lost the reservoir in the trunk, and I threw away the junk inside the fender because it was too bad.
I am thinking about getting a reservoir and running a simple plumbing with a pump preferably using factory wiring.
I am sure bunch of you cats have done this before. Any pointers before I go my way.
Thanks bunch. Double thanks if you post pictures.
Uwon 12-16-2015 04:16 AM
I simply ripped out everything ( including the headlight washer pump) save the intensive wash reservoir which sits beside the brake fluid reservoir on the '86 and hooked it up to the regular washer pump.Hope this helps.
Cheers,
Johan
javadog 12-16-2015 04:47 AM
This very topic was discussed (again) last week. There are now several threads out there on the subject.
JR
Pazuzu 12-16-2015 06:46 AM
http://forums.pelicanparts.com/porsche-911-technical-forum/894299-lightweight-windshield-washer-tech.html
impactbumper 12-16-2015 10:46 AM
JR
People like you make me hate internet
Thanks man, saw that. Appreciate it.
Cheers,
Johan
Thanks man that is what I was thinking.
javadog 12-16-2015 10:56 AM
Well, I'm sorry. People like you make me irritable because you never take the time to try to see if it's been asked and answered before. It takes all of ten seconds to do a search, but you'd rather someone else do your work for you.
I know I've answered this question in at least a half dozen threads here and I'm sure I didn't reply in all of them.
Have a nice day.
JR
brianlay 12-16-2015 11:01 AM
Well said!
javadog 12-16-2015 11:23 AM
I took a look and found more than 20 windshield washer threads where I've responded. Here are three more that have enough info to answer your question:
http://forums.pelicanparts.com/porsche-911-technical-forum/854199-lightweight-smaller-washer-bottle.html
http://forums.pelicanparts.com/porsche-911-technical-forum/867214-washer-system-choices.html
http://forums.pelicanparts.com/porsche-911-technical-forum/367664-need-any-info-high-intensity-washer-conversion.html
JR
Uwon 12-16-2015 06:42 PM
Have a nice day.
JR
Hey javadog.
I hope that you did not intend to be so harsh. Most of us are just enthusiasts with far less forum/Internet experience than you have with some 12,000 posts on this forum alone over he past 10 years.
I, for one, do appreciate your knowledge. Just please lighten up and just share.
Johan
RSBob 12-16-2015 07:34 PM
Not pileing on Javadog due to the great authority he is on many things 911. But it is a reminder to all of us that many are not interweb savy, don't have backgrounds in engineering or IT, but are just occasional users.
My dad comes to mind when I had to explain what Craig's List was and it is a great way to get rid of stuff you would normally take to the dump but put "Free" on it and people will beat your door down to get it. He asked how that was possible and I said, ask the Google because it knows all becuase sure as s*** I couldn't figure it out.
Winter 12-16-2015 08:04 PM
Just imagine how much you'll LOVE the internet, and how much information you'll be able to quickly and easily access by using the search function here.
Not trying to be a dick, just saying that I've learned a ton by checking out the massive archive of threads on all things 911 here.
I have to say that our host has set things up really well when it comes to the search function and it's hugely useful.
Although I can understand that some may wish to not use it, for whatever personal reasons they have. . . No worries there. It's just that those people are missing out by not taking advantage of the knowledge they could access.
After all, guys like Grady aren't around any more to reply to new threads, but their wisdom lives on in the archives.
Good luck with your project!
impactbumper 12-16-2015 08:06 PM
Originally Posted by javadog (Post 8920398)
Thank you.
Originally Posted by Uwon (Post 8920976)
Hey javadog.
Johan
Funny thing is these cars are as old as 50 years. So everything imaginable has been done to them. Any technical question is probably has been touched, answered, covered here, or elsewhere on the internet. So what are we going to do with these forums? Is it too much to ask a simple question to get some pictures for inspiration? One idea leads to another. One of the threads a guy used a Volvo tank, that is creative. I was trying to see different applications.
Sometimes it is wise to keep quite if you do not have anything positive to say.
I am sorry if I am too harsh here.
spyerx 12-17-2015 12:54 PM
You can see my post here, starting #22 for what I did with my 964. The 911 part is very similar. I basically deleted the huge tank in the fender, picked up the intensive tank, wired that into the huge tank wiring for the pump,used the OEM mount flange which was already there. My car did not have the intensive system stock, so this worked fine plumbed into the washer tubing. if you has the intensive system you'll need to cap off one set of pipes, they are 2 different systems but connect at the washer nozzles. Look at the PET and you can see.
My 964 C2 Transformation Build Thread - Rennlist Discussion Forums
