rear bumper fitted w/tow hook
http://forums.pelicanparts.com/uploa...1456175204.jpg http://forums.pelicanparts.com/uploa...1456175315.jpg Front bumper oil cooler cut out http://forums.pelicanparts.com/uploa...1456175270.jpg 62 twin grill sitting off to the side http://forums.pelicanparts.com/uploa...1456175362.jpg |
Factory Porsche Fuchs wheel caps came in today. These fit the 17" Fikse/Fuchs.http://forums.pelicanparts.com/uploa...1456327947.jpg
http://forums.pelicanparts.com/uploa...1456327962.jpg |
Love the build. Glade to see someone being creative in my back yard. What's up with the oil lines? Just dropped for easy access or replacing???
ER front mounted oil cooler kit with finned lines, setrab cooler, air deflection panel, new thermostat, high clearance lines, crossover pipe and all install parts showed up today. Well needed as it gets hot here in Florida, especially down at Sebring when your running full out!
http://forums.pelicanparts.com/uploa...1458053062.jpg http://forums.pelicanparts.com/uploa...1458053087.jpg http://forums.pelicanparts.com/uploa...1458053101.jpg http://forums.pelicanparts.com/uploa...1458053155.jpg Also received the Rothsport lightweight fiberglass lamp buckets, supposedly saves around 6.5 lbs off the rear end. They are very very light. They accept the factory rubber seals and lenses. http://forums.pelicanparts.com/uploa...1458053229.jpg http://forums.pelicanparts.com/uploa...1458053259.jpg http://forums.pelicanparts.com/uploa...1458053286.jpg |
The above oil cooling kit diagram
http://forums.pelicanparts.com/uploa...1458055284.jpg |
Last but not least, Wevo classic shifter with precision shift joint and light weight shift knob. The car should go back together rather quickly now I'm hoping. SmileWavy
http://forums.pelicanparts.com/uploa...1458164228.jpg http://forums.pelicanparts.com/uploa...1458164247.jpg http://forums.pelicanparts.com/uploa...1458164264.jpg |
Nippy, where did you find these things? ROthsport doesn't list them on their website that I can find. I need a set!
How stout are the FG rear housings since they tend to get blasted by rocks thrown off the tires? Anybody else own these?
Looking good Nippy! But that carbon fiber dash is awful, LOL.
fenders in primer, fitting the getty hood. Sunroof welded smoothed and primered
. http://forums.pelicanparts.com/uploa...1458328113.jpg http://forums.pelicanparts.com/uploa...1458328134.jpg http://forums.pelicanparts.com/uploa...1458328149.jpg |
Nippy. I see you purchased a new thermostat with the oil lines. Do these go bad? Or is it just preventitive maintenance?
I have the wevo classic shifter also, and love it. I also have the same center oil cooler and mounting brackets. Very nice solution. Great build. You have me thinking about my sunroof.
If anybody needs 911 tail light housings...
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/906737-2-tail-light-housings-911sc.html http://forums.pelicanparts.com/uploa...1458486963.jpg |
WEVO motor/tranny mounts came in
http://forums.pelicanparts.com/uploa...1458843072.jpg http://forums.pelicanparts.com/uploa...1458843089.jpg |
What helped you pick the Patrick roll bar? I like how it mounts, as the others mount to the floor pan... Patrick seems to give more room, and hides the bar better...
There is only one that I can think of that mounts to the floor and I think you see that one more because its cheap.. of course I can't remember the name right now... but ?? |
Oil cooler front air deflection panel was welded in. Test fitted the ER Setrab front mount oil cooler and also the front bumper with cut out. Everything turned out nice. Front end metal going to be put into primer now.
http://forums.pelicanparts.com/uploa...1459799231.jpg http://forums.pelicanparts.com/uploa...1459799245.jpg http://forums.pelicanparts.com/uploa...1459799257.jpg |
Are you mounting the screen from behind? The oil cooler is my next project.
http://forums.pelicanparts.com/uploa...1460065134.jpg |
Couple little things taken care of. Car is taking longer than expected.
Getty hood trimmed a bit and fitted. Can also see windshield squirters removed and filled http://forums.pelicanparts.com/uploa...1461782420.jpg Front oil cooler deflection panel and surrounding area put in sealant http://forums.pelicanparts.com/uploa...1461782451.jpg Interior view of sunroof panel welded in and and sealed http://forums.pelicanparts.com/uploa...1461782493.jpg Removing old paint (has had 2 paint jobs). http://forums.pelicanparts.com/uploa...1461782555.jpg |
new door jam Vin sticker recreation just came in today! Thanks again to noboco here on the forum! These are NLA from Porsche.
www.carbone.pl http://forums.pelicanparts.com/uploa...1461938841.jpg |
Wonderful text and photos Nippy!
Got the Halon fire extinguisher and the Buckley racing mount that uses the factory E brake mounting points.
http://forums.pelicanparts.com/uploa...1462721349.jpg |
Found some cool "lightened" door handles on Fleabay. We snapped an internal pc. on my factory door handle, so I was poking around and found these. Ordered 2. Cool little touch.http://forums.pelicanparts.com/uploa...1462815273.jpg
Subscribed due to the insane nature of this build :)
Found some vids on U Tube made by the previous owner, I'm really jonesing to get my car back at this point as its been gone 5 months now, I drove it for 1 day. :mad: I know, I know, my own fault but I know its going to be worth the wait!
<iframe width="560" height="315" src="https://www.youtube.com/embed/7puvzLxBuM4" frameborder="0" allowfullscreen></iframe> <iframe width="560" height="315" src="https://www.youtube.com/embed/ryt_Lx9vQxY" frameborder="0" allowfullscreen></iframe> <iframe width="560" height="315" src="https://www.youtube.com/embed/tZxRq53vQC4" frameborder="0" allowfullscreen></iframe> |
So I ordered an extra set of cushions for the Corbeau seats. I'm going to have them covered in either the tartan shown here or the Hounds tooth. Will use these for cars and coffee or car shows and use the standard black for normal driving and track use.
http://forums.pelicanparts.com/uploa...1464106946.jpg http://forums.pelicanparts.com/uploa...1464106996.jpg http://forums.pelicanparts.com/uploa...1464107031.jpg http://forums.pelicanparts.com/uploa...1464107044.jpg |
5 months nothing i am 1 year into it after a day of driving. Almost there though. How do you like the Corbeau seats?
Sent from my iPhone using Tapatalk |
Todd |
http://forums.pelicanparts.com/uploa...1464281937.jpg |
I like that solution. I am not 100% happy with the under seat options.
| All times are GMT -8. The time now is 05:35 PM. |
