LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average.
911 tweaks's Avatar
++ above...
Everything must be thought of as a system....
I live for 911 tweaks...
Old 02-16-2019, 05:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #721 (permalink)
Under the radar
Trackrash's Avatar
Originally Posted by kent olsen View Post
I'll throw this out there for what it's worth.
All the early cars, all makes, ran 14-15" wheels and tires with big sidewalls. The manufacturer designed the suspension with the give of the sidewall in consideration with the suspension. Soft or firm depending on the application, Cadillac or Corvette/Sportscars. Now we have the new generation coming out with 17-18-19-20" wheels with 30-40 series tires that have no sidewall give at all, it must be all in the suspension. It seems to me that if you go the larger wheels/small sidewalls on an early car your suspension will not work at all. Of course we can procrastinate and say it's just stiff because it's more like a competition suspension.
Just my opinion
You have to remember that "modern" cars have a suspension sub frame that isolates much of the tire's ride harshness.
Don't most race cars use 18" wheels? Seems >18" is just looks.....
BTW, I LIKE my 16" wheels.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-16-2019, 06:11 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #722 (permalink)
Yeah looks that’s what it is ....
Old 02-16-2019, 07:55 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #723 (permalink)
nippy's Avatar
The sidewalls on my 17s are still pretty large. I do see what your saying in 18" and larger. I had 18s on my 930. The 17s seem to be the sweet spot since 16" and 15" are getting harder and harder to find. Hell the only company that make my 17s is Continental in the sizes I use.
16 Boxster Spyder (sold), 82 911 Wide body/Miami blue/Mike Bruns built 3.6 (sold), 80 911SC Black/tan (sold), 87 930 Turbo 505 slant GP white/black (sold), 95 993 C2 GP white/tan (sold), 82 911SC Hot Rod lightweight Black/black (sold)
Old 02-17-2019, 09:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #724 (permalink)
nippy's Avatar
Hopefully the car will be done in a month.
Old 02-17-2019, 11:21 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #725 (permalink)
KTL KTL is online now
Schleprock
KTL's Avatar
Tire usage/choice is unfortunately often driven by availability. If people ain’t buying a tire size/diameter, tire makers don’t make them. Just that simple. So it leaves us to seek out another size
That said, I respectfully disagree with Kent’s assessment in saying the suspension doesn’t work “at all” with tire diameters different from those sizes original to the car. The wheel sizes for the earliest cars were sized around the size of the brakes- you need a wheel big enough to clear the brakes and not much more than that. Plus, tire construction and materials have changed a ton since the 911 was first designed
My own experience with the suspension working has been good. My ‘79 car running 17” wheels was able to perform very well against good drivers with newer 993 cars running 18” tires. However there’s also guys running 15” Hoosiers in PCA stock class that are very fast cars. Those 15s run shorter sidewalls (275/35 rears) that bring down the ride height and also establish a higher effective gear ratio for faster acceleration due to greater torque multiplication. So it’s not as easy as saying these cars were designed for 14” & 15” wheels and anything else is less than optimum
Kevin L
'86 Carrera "Larry"
Old 02-17-2019, 11:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #726 (permalink)
GaryR's Avatar
Send a message via ICQ to GaryR
Agree with Kevin, my experience is 95% track use (DE and Racing) and we started out with 31/24 TB's and 275/35 245/40 18's on our PCA Stock D SC's. We went to the max size TBs (35mm IIRC in the rear) and 275/35 15's and with the gearing advantage dropped track records across the board. The system worked well, as long as we kept the suspension movement and didn't lower the car too much all was well...
Gary R.
Old 02-17-2019, 02:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #727 (permalink)
kent olsen's Avatar
Good points Kevin
I guess what I'm trying to point out is the set ups with 2" sidewalls. To me all the suspension is "in the suspension". Old cars with (65-70) sidewalls had considerable give in the sidewall with somewhat stiffer suspension. Hence my feeling narrow sidewalls on an older car would be a stiffer ride on a street car.
I remember many years ago when my wife ran into a deep pothole and bent a rim. When I took the wheel to the tire shop and asked if it was possible to straighten the rim the shop said "NO". He also commented that since they came out with narrow sidewall tires he'd been making much more money replacing wheels than selling tires.
Kent Olsen
72 911 SCT
upgraded 3.0L
McMinnville, Ore
Old 02-18-2019, 07:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #728 (permalink)
nippy's Avatar
Ok the new larger fuelab filter is plumbed in. Waiting for tranny work then BOOM, in the car it goes. Then lower, align, corner balance and final tune of the carbs from Mike. I can almost see a small dot of light at the end of the tunnel.
Old 02-19-2019, 12:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #729 (permalink)
nippy's Avatar
I suck at making videos, lots of mess ups but oh well. Carbon fuse panel, not engine shroud. LOL. Anyway, here ya go.
Old 02-27-2019, 09:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #730 (permalink)
shouldn't your wipers be resting on the other side of the windshield?
1987 Porsche 911 Carrera Coupe
Old 02-27-2019, 10:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #731 (permalink)
nippy's Avatar
Very common modification to get the wipers out of the drivers field of view.
Old 02-27-2019, 10:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #732 (permalink)
nippy's Avatar
A few people asked me to make a video of the gauges with the LED upgrade. Here ya go.
Old 03-04-2019, 02:27 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #733 (permalink)
nippy's Avatar
If anybody wants to go to Sebring 12 hour, just listed my tickets and PCA corral parking pass.
SEBRING Porsche Corral parking pass/2 tickets $250
Old 03-05-2019, 08:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #734 (permalink)
nippy's Avatar
Not the most exciting parts but the bearings came in for the tranny. All OEM of course.
Old 03-05-2019, 01:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #735 (permalink)
Schleprock
KTL's Avatar
Fairly recent dates on the bearings from 2012-2016. I got rod bearings last year from the dealer that were dated 2008!!!!
Kevin L
'86 Carrera "Larry"
Old 03-05-2019, 01:54 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #736 (permalink)
nippy's Avatar
Yeah I saw the 2012 and thought that was pushing it......
Old 03-05-2019, 02:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #737 (permalink)
nippy's Avatar
Another boring part....OEM windshield gasket for the now cracked windshield. The windshield man is on his way over here now, so we shall see.
Old 03-06-2019, 10:14 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #738 (permalink)
nippy's Avatar
Man the guys pulled it off! No more gaps in the corner to let water in! Bay Area Glass works came through! The cost was even better, FREE.
*Bonus-no more mirror puck on the windshield from the old glass mounted mirror!
Old 03-06-2019, 12:03 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #739 (permalink)
nippy's Avatar
Ok so now were getting somewhere. WEVO parts came in today along with the differential carrier bearings and a bottle of Swepco.
Transmission Side Cover
XT-032 Bearing Retainer Plate
Old 03-07-2019, 09:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #740 (permalink)
