No start with Pertronix?
Just fitted a 2862 Pertronix onto my Bosch distributor, and a 3ohm coil on my 1970 911T. Now it won't start. Anyone fitted these and had a no start issue, what did you do? Very frustrating!! Cheers
Get rid of the pertonix and put the points back in they last 30,000 miles. Never been a fan of Pertonix many friends say they're crap and I agree.
Plus one!
Agree with Gomezoneill! I built a Datsun Racecar everything new, including new Petronix, we spent several race events and one ruined engine (detonation) due to a junk Pertronix.
We checked the wiring at least 5 times, and it was correct. Finally out of frustration we replaced it with points and the problem was solved! I will NEVER EVER EVER use one again! :mad: Jeff |
I have been there PZSPEED
Clearly not every Pertronix is defective, but having experienced it, the hard part is diagnosing when it doesn't work
I know others have had similar experiences, so I prefer to keep things simple |
Hi RyanH,Pertronix is a great product, dont be put off,i have used there product on about
5 classics over the years,and its terrific,i always carried points in trunk but never had to use them.You have probably fitted something incorrectly ,so check it out ,depending where you purchased them from, they will give you advise as well,there are many forums here on fitting just have to find them,regards. |
First, spark at the coil? at the distributor output? Timed correctly?
12 volt bulb between 12v and distributor/pertronix output flashes on/off as you crank the engine? |
Hi,
Given that the latest Bosch points are now a POS, Pertronix becomes a viable alternative given one caveat. I've seen as much as a 4 degree, cylinder-to-cylinder variation in timing with the Pertronix units so I always check & confirm timing on each & every cylinder so none of them exceeds my targeted total values. Failure to do so may result in one or more cylinders detonating and ruining some P/C's. |
Needs more smoke.
I have had very good experience with Pertronix . Had one in my 1973 911 for 8 years. No problems.
Teamed with Daytona Sensors CD1 CD I it works great. |
LIkewise here. Pertonix, MSD box, coil and all is well for years now.
Does your car have a CDI? Pertronix is wired differently for a car with CDI.
Here's a link to the CDI wiring diagram. http://www.pertronix.com/support/tips/pdf/porsche_cd_diagram.pdf |
No need for wise ass remarks on the board either. |
A common problem is the magnet is not completely seated on the dizzy shaft- need to ensure its pressed all the way down.
Thanks for all the replies guys. I'll give it until the Christmas break and try a few more ideas, including an auto electrics friend and if it won't start its coming off. I've lost a lot of faith when it didn't fire up, as I was told it would, first time. I could keep the 3ohm Flamethrower coil with points couldn't I?
Yes, three ohms is the minimum primary resistance for use with points. Bosch designed them to carry four amps, so 12V (nominal) divided by three ohms gives you four amps. Any more current and you will burn the points.
Why don't you post here a drawing of how you wired the pertronix and a few photos, they are pretty easy to install but there are opportunities for a mistake now and then when they don't work. |
I do see merit in wise-ass remarks when comments indicate you will blow an engine if you use this part. I see that as horse crap. What John Walker says appears valid, or at the very least, worthy of study. The rest is hearsay. Your knowledge history is as valid as the next guys until proven wrong. It's a forum. Stick around. |
John & I speak frequently and he's a damned sharp cookie. |
All I am saying is your comment is the one that made sense and had validity from a technical standpoint. I did not discount John either so why the damned sharp cookie comment? |
In the English language, its considered a term of endearment. |
... easy up Bob and Steve, I could use the spark between you two to start my frickin car!! Seriously, thanks for all your input I'll keep on trying and keep the post running when/if I find a solution...
This is not the first and most likely not the last thread on the pros and cons of the Pertronix Ignitor and 911's. It seems there is little middle ground, those who have tried them either love them or hate them. I installed the Pertronix in my '74 in 2002 and it is still going strong so count me in the former group. I do keep the points I pulled back then in the glove compartment but am not sure why anymore.
Yesterday morning he posts this on my Facebook page: http://forums.pelicanparts.com/uploa...1450702956.jpg I said "Awwwww" It got 28 "Likes" So I return the favor and post on his Facebook a nice picture from a college football game between a school from his state (Oregon) and a school from my state (Ohio). Boom! He blows his stack. You never know with Steve. It's like, what did I do? http://forums.pelicanparts.com/uploa...1450704136.jpg http://www.nytimes.com/2015/01/13/sports/ncaafootball/ohio-state-upsets-oregon-and-wins-national-championship.html?_r=0 |
So, moral of this story is of course 'if it ain't broke don't try and fix it'. I gave up and put my points back in as the Pertronix set up would not start my car. I put the points back in but kept the Flamethrower, still won't start. Put the old Bosch distributor back on, still won't start. Why oh why did I touch what was working fine! Looks like the holidays will be spent on the car and not in it, damn it!!
| All times are GMT -8. The time now is 10:10 PM. |
