-   -   advantage of twin plugging? (http://forums.pelicanparts.com/porsche-911-technical-forum/89570-advantage-twin-plugging.html)
Chuck Moreland 12-04-2002 10:14 PM
Ah yes, the benefits of twin plugging are obvious.
Tongue firmly in cheek :p
Kevin Stewart 12-04-2002 10:47 PM
Thanks Wayne, im putting a 3.6 in and was wondering why the dual distributor, my questions are answered, makes since, Kevin
Bobboloo 12-04-2002 10:53 PM
HP vs. Torque and the bicycle theory!
Hey Island,
I just thought of how your bicycle parallel relates to the difference between HP + Torque and why twin plugging helps more with torque than with horsepower.
When pedaling a bicycle from a standstill you want to exert the most force you can from 12:00 o'clock on the pedal(piston) continuosly to 6:00 o'clock. This gives you torque.
After you're moving at a clip the issue becomes staying in sync and feeding (flow) the pedals (pistons) to sustain the momentum or HP if you will. This is why flow is criticle to HP.
Bobby:)
dougcl 12-04-2002 10:57 PM
Oh my.http://www.pelicanparts.com/support/...s/visslaan.gif
island911 12-04-2002 11:08 PM
http://forums.pelicanparts.com/ultimate/icons/icon3.gif
:) fishheads withstanding. . .
Right, "spinning" (as the crowd soon to invade with bicycle manutia, will tell you) is the way to get HP to the road. You don't force the pedals nearly as hard as you could (torque). Instead, you put the forces in much more often (than when jumping on the pedals)
ChrisBennet 12-05-2002 03:29 AM
Originally posted by CamB
Just to add to Chris' (Bennet) comments, I think you need a second Bosch CD box (or two MSDs and sell your one Bosch CD box to recoup the cost!).
Just so Camb and I don't confuse people. CamB's method applies to pre 3.2 motors. A 3.2 just uses a "splitter box" to run a 2nd coil.
-Chris
jluetjen 12-05-2002 04:38 AM
Bobby - Your observation is profoundly sublime!:eek:
CamB 12-05-2002 01:14 PM
Uh yeah - sorry for confusing anyone (I actually had no idea the Carrera was so different - don't I look silly :o)
