-   -   Where to put trans oil temp sensor? (http://forums.pelicanparts.com/porsche-911-technical-forum/89587-where-put-trans-oil-temp-sensor.html)
ohecht 12-03-2002 02:22 PM
I am looking for a decent way to install a transmission oil temperature sender onto a 915 transmission.
I would prefer to do something fairly easy from the outside that is reversible, like replacing a case bolt, fill or drain bolt, or a magnetic probe or ring mount.
Does anyone know of some good methods fitting this criteria? Tread sizes and pitch for the bolts? Depth available behind the opening, etc.?
Here is a page with some sending unit options.
http://frostalarm.com/cat/p34.html
Thanks,
Olivier
widebody911 12-03-2002 02:46 PM
Perhaps something that replaces (but maintains the functionality of) the vent on top?
TRE Cup 12-03-2002 02:49 PM
We have used the filler plug on the side of the trans case. You can drill and tap the plug for the vdo available sender. That way the hot trans oil splashes up against it while driving. You can't place it in the vent tube up top.
ohecht 12-03-2002 03:34 PM
Through the fill plug sounds like a good idea to get inside without major work or potential damage.
Do you know a good size to use through the fill plug? I think I also need to consider the depth so there is no interference with parts inside the opening.
Thanks again.
Olivier
Tim Walsh 12-03-2002 04:13 PM
For a second I thought you were the one with the transmission cooler but my vote would be through the filler plug. But would that hit anything or get in the way inside?
my $0.02 worth of unexpert opinions
TRE Cup 12-03-2002 05:51 PM
The VDO part number is 323 095. This is a sender that screws into a 1/8" 27 thread NPT (this means pipe thread/tapered) hole.
You can purchase the drill and tap at local hardware store. Check with Pelican re: the sender and matching guage.
This does NOT interfere with internal parts of the trans in any way.
ohecht 12-03-2002 08:42 PM
Thank you, I will look for that part. Once it is installed, I assume you just remove it each time you need to check the fluid so the 19mm allen can fit into the plug?
Olivier
TRE Cup 12-04-2002 11:07 AM
just use a deep socket and leave the sensor attached to the plug. No sense making work twice. The sensor has a slide on connector, so removing the wire is no brainer
ohecht 12-04-2002 03:43 PM
My plug is a recessed 19mm allen, so I don't think that would work.
Is there another type of external hex plug I could use instead to avoid removing the sender to get the fill plug out? Thread size, etc.?
Olivier
TRE Cup 12-04-2002 05:15 PM
some of the 915 equipped cars (72-89 production run on the basic trans) have the external hex plug. Check with some of the shops in your area to see if they have one. We would sell you one, but we like to hoard them for trans pump installs.
ohecht 12-04-2002 06:21 PM
I understand...do you have the thread size and length of the bolt?
TRE Cup 12-05-2002 08:54 AM
24mm x1.5 thread pitch x 17mm long. (Do NOT use the drain plug from the motor /oil tank- that one has a bevel for a seal ring- won't work on the trans)
ohecht 12-05-2002 09:33 AM
Thank you, I will start looking for such a bolt.
Olivier
