-   -   Seal replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/895890-seal-replacement.html)
Slanski62 12-22-2015 12:46 PM
Seal replacement
Hello gang. I recently posted about moisture in my car. Well today, after a heavy rain last night, I had water standing in my driver's side foot well. I'm now dead in the water with my interior resto until I get my car water tight. Which brings me to my question: does anyone have pictures of all the seals around the cabin and how they're supposed to fit? I suspect I'm missing some based on the diagrams, but I can't tell from the drawings where everything is supposed to go. Any help is appreciated. Best regards.
Steve Yeatts
gomezoneill 12-22-2015 01:06 PM
Can't help with the photo's but you may have a clogged sunroof drain on either side that will cause leaks that is, if you have a sunroof.
Slanski62 12-22-2015 02:19 PM
Thanks gomezoneill. I did have clogged drains, but they were cleaned out.
universeman 12-22-2015 04:30 PM
have you replaced all seals? Windshield seal and trunk seal are notorious for flooding driver foot well. I replaced both of mine - huge help.
Slanski62 12-22-2015 05:32 PM
The PO says he replaced them, and they do look new. But I don't know if he used Porsce, OEM, or Uro. There is a visible gap in the upper left corner of the windshield. So that one is definitely suspect.
