Replace oil and seals and sometimes the washer/shim stacks. The oil eventually gets contaminated and that accelerates wear on seals and metal parts. Apparently the thin metal washers/shim stacks in the shocks with time deflect and need to be replaced too. Off road racers in extreme conditions do this a few times a season. Production car shocks are said to last 50,000 miles. ymmv :) A set of adjustable racing shocks that cost $2k to $4k+ that get rebuilt for $300 makes sense. If you have less expensive shocks just replace them in pairs. |
How much compression is in a good jounce? I cant even jounce my race cars or 1 ton truck. :) |
Are you road racing where custom-valved shocks are mostly used? If not, standard, HD or sport shocks should be enough options for most owners. However, as always, YMMV.
Sherwood |
| All times are GMT -8. The time now is 07:09 AM. |
