911 SC shifter rotating?
Merry Christmas!
So my shifter isn't loose or wobbly, but it rotates, especially when I throw it out to go into reverse or fifth. I pulled the skirt up and watched the stalk turn in the bearing. I think a weld popped? Or maybe epoxy gave out? In any case, is this something I can just epoxy to keep it from rotating? Thanks! |
http://forums.pelicanparts.com/porsche-911-technical-forum/568110-911-shifter-broke-off-stranded-1st.html
http://forums.pelicanparts.com/uploa...1159891256.jpg Original is epoxied, most recommend a tack weld to fix. |
What is easiest way to remove the shifter to weld it?
Did this weld fix with the shifter in situ about 10 years ago. Just ensure you're well grounded. . .
Thanks for tip
| All times are GMT -8. The time now is 11:53 AM. |
