Headlight trim ring screw
Does anyone know the size of the little screw that secures the headlight trim ring to the headlight screw? I'm installing new trim rings, but they didn't come with the retaining screw.
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 03-31-2016, 07:36 AM
Spiderman
Jesse16's Avatar
I think our host actually sells those as a separate item. As I remember, they aren't too bad price wise. Mic's as and M4x10 long thread. Philips head and machine head by the look.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 03-31-2016, 08:46 AM
I believe the part you are looking for is 900 270 063 07, assuming you have H5 trim rings. Note however, that you need to pay attention to the note and to the reviews in the part description. The part Pelican supplies is M5 x 18 mm. This was too short for my 1988, which uses a 27 mm I believe. If you have the old ones measure them before ordering new.
_______________
John
1988 Carrera Targa 3.2 G50 - Sold.
2017 Chevy Silverado K1500.
Old 03-31-2016, 09:55 AM
Spiderman
Jesse16's Avatar
What I measured is the screw on my H4 Rings. The "upgrade" our host sells when ditching the H5's. I believe its, Part #: 911-631-132-00-M260 Cost is $1/ea.
Old 03-31-2016, 10:01 AM
Are you talking about this screw ?
If you are I can tell you what size it is when I get home tonight.
Old 03-31-2016, 03:51 PM
Believe you also need to purchase the screw on the right (above) to install the trim ring, it has a female thread that accepts the screw that holds on the trim ring -- the screw used on sugar scoops in this position is a normal screw
Old 03-31-2016, 04:06 PM
Found a replacement
Yep, it's the little one that fits inside the main retaining screw.
I needed it by Saturday, so I went and found a match at Fastenal.
For anyone who needs a fast replacement, here's the one I went with. I just painted it guards red and it's pretty much invisible. Sorry if the picture is sideways
Old 03-31-2016, 05:59 PM
Undocumented User
McLaren-TAG's Avatar
I love Pelican and buy quite a bit from them but you guys do know that it's absolute lunacy to order every single bolt, especially if you need it yesterday from them. True Value, Ace or any other local mom and pop hardware store is going to have the bold you need.
I bought an allen head stainless steel one for that application for $0.45.
Old 03-31-2016, 06:24 PM
You got it.
That is the size screw you need.
But instead of a hex head bolt, you can use a stainless steel pan head phillips screw.
M4 0.7 pitch 10mm long . Both screws are stainless steel.
Old 03-31-2016, 09:05 PM
