'73 911 T Targa
How do you feel bout using POR Patch for filling screw holes
I have a series of holes from sheet metal screws that held the clamps that secured the air conditioning tubing I just removed. I was thinking about simply replacing the old screws with stainless steel screws. Now wondering if the POR patch or a combination of POR Patch and stainless screws might be a better choice. Any Thoughts about this or other options?
Here's a link to the POR Patch
http://www.amazon.com/POR-15-49013-Black-POR-Patch/dp/B00J594AQ2/ref=sr_1_4?ie=UTF8&qid=1451878277&sr=8-4&keywords=Por+15+sealant
Old 01-03-2016, 06:40 PM
Reiver
Reiver's Avatar
Sure, that would work...so would Kwik Weld...
De Oppresso Liber
Strength and Honor 5th Legion
Old 01-03-2016, 07:47 PM
I use a dab of black silicone paste from a tube and smooth with a finger.
206 637 4071
Old 01-03-2016, 08:07 PM
Eng-o-neer
Tremelune's Avatar
I wonder how this stuff would fair in the 1/2" holes left behind by a 5-point harness bolted through the floor...
Old 01-03-2016, 08:42 PM
Almost Banned Once
sc_rufctr's Avatar
This... The POR Patch would work well but it would be much harder to remove if needed.
- Peter
Old 01-03-2016, 08:46 PM
Lousy. Buy some plastic or rubber plugs made for this purpose and install them with some sort of sealant. Look at your car, Porsche used a variety of plugs all over it.
As for the small holes left by a screw, put the screw back in the hole and seal over it.
The POR product is probably just another sealant. You can find dozens of them at any auto parts store. I like 3M products myself.
JR
Old 01-04-2016, 04:20 AM
Like you, I took the screws out for air cond. tubing, but didn't do anything with the holes for quite some time. Now, I'm worried about rust starting in the holes. Is there a good solution for making sure no rust exists in there, and sealing it. Thanks
Don Ivey
'87 Carrera
'13 Scion FR-S
My Porsche tinks, therefore I am.
Old 01-04-2016, 05:01 AM
BFT3.2's Avatar
I used clear flexible Permatex silicone sealant for my AC hose holes.
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 01-04-2016, 05:30 AM
