Testing a differential
So today I turned the rear wheels as the car was raised from the ground, and noticed the wheel on the other side doesn't turn the other direction (so no LSD). However, I thought that no LSD means the wheels will turn in the same direction? My 'other' wheel doesn't move at all... :confused:
Nope, that is normal for a Standard differential. When you peel out from stand still you will notice only one set of rubber tracks.
Cheers DRACO A5OG!
| All times are GMT -8. The time now is 04:35 AM. |
