LinkBack Thread Tools Rating: Thread Rating: 3 votes, 3.67 average.
final touches with grill mounted and the drain hose
Old 11-14-2020, 04:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #141 (permalink)
Now that the ventilation system is fitted, Rennfrog has finalised the braking system and the pedal cluster.
The rigid braking lines had to be modified to fit.
The rear light switch is visible here.
Pedal cluster finally in place.
Nice :-))
Braking force F and R is adjustable from the cockpit
Old 11-14-2020, 04:41 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #142 (permalink)
Is that a aftermarket fresh air box? Where can I get one?
Old 11-14-2020, 07:15 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #143 (permalink)
yes, but it has been modified to insert the "butterflies" (see the entire process described in post#140 above). It is sold bare by DP Motorsport in Germany.
Old 11-14-2020, 07:28 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #144 (permalink)
In keeping with the spirit of this build, we replaced the electrical heating controller by the manually operated levers used on the early impact bumpers.
All parts duly restored.
A beige carpet was sourced at appbiz
Locating the fixation of the 4 points RSR loop
The RSR roll bar received an epoxy coating
Old 11-14-2020, 12:08 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #145 (permalink)
The 044 pump is nestled in a protective rubber cover to make it silent
The turbo arms are back where they belong
Old 11-14-2020, 12:09 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #146 (permalink)
We are blessed with quality options for the 930 shifter. We chose the rennshift as it came as a complete unit.
shift coupler was also upgraded
Old 11-14-2020, 12:15 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #147 (permalink)
We changed the factory black window frames for chrome ones (actually clear anodised). We picked and chose the elements from various sets...
A good cleaning was on order
The "hinges" were also renovated
[hr]
[hr]
Old 11-14-2020, 12:34 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #148 (permalink)
Final touches for the interior
door rubber seals
[hr]
[hr]
Old 11-14-2020, 12:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #149 (permalink)
Time to mount the stock front bumper
[hr]
[hr]
Emblematic of early G body are the "periscope" washer jet. This nice repro set iscoming from Austria.
[hr]
We deliberately fitted them non functional - to have the look without the weight penalty of a tank and hose..
However repros come without the fitting clips. We used calipers clips from Porsche.
Old 11-14-2020, 12:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #150 (permalink)
Pictures are worth a thousand words...
Old 11-14-2020, 12:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #151 (permalink)
Brando
quattrorunner's Avatar
This is the most beautiful build.
Turbo powa!
1977 911s. it's cool
Old 11-14-2020, 01:14 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #152 (permalink)
Jonny042's Avatar
AMEN!!!
I'm not easily impressed, but this is one of my favorite builds. Mind blowing attention to detail.
No expense spared, no shortcuts, no compromise. I know the car has been done (and revised?) and really look forward to future updates.
87 Coupe - The Driver
78 Backdate - The Project http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered.html
85 Coupe - The Rot Rod! AX beater
Old 11-15-2020, 06:10 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #153 (permalink)
Thanks a lot for your encouragement :-)
The engine bracket was not rigid enough - so a gusset was added and holes were drilled for that RSR look. It is shown below before paint.
Doors fresh from the painter. cockpit side was painted black just like factory did.
Windows cranks have been converted to manual and the rack was refurbished.
The leather strap had to be brown to match ;-)
Old 11-15-2020, 12:20 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #154 (permalink)
Door windows can now go back where they belong
Starting to look like a car again
Old 11-15-2020, 12:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #155 (permalink)
The engine lid remote handle is mounted
New front indicators
The fuel tank has been modified and is shown before paint.
New wiring loom for the Cibiť additional lights
Ready to go
Old 11-15-2020, 12:25 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #156 (permalink)
We chose to put a PC680 batterie - which is enough given that the eletrical system has been considerably reduced. As it is already very light, we kept it in its original location rather than moving it to the smugglers' box.
But black it had to be to look more factory.
A heated windshield was fitted - and we put the related switch in lieu of the AC blower switch.
The tartan covered door panel is ready to go in
[hr]
Old 11-15-2020, 12:35 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #157 (permalink)
Fuel tank ready to go with protective coating unerneath
all the ancilliaries are renovated.
Time to address a key topic on the 930: the gearbox. It is arguably the element that has received the most attention.
It is a great gearbox, designed for racing. Utterly solid, light and great to work on: a true gem of a gearbox. But... the fatory gear ratio are extremely long to reduce fuel consumption and noise level on the highway. We kept the first gear stock while the remaining 3 were shortened circa 10%.
We also installed an oil cooling system with electric pump.
Old 11-15-2020, 12:44 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #158 (permalink)
Old 11-15-2020, 12:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #159 (permalink)
The gearbox was also converted to a "short bell" type, by removing circa 27mm from the casing / the shaft. It is a great mod allowing to fit sachs sport 934 style clutch (removing 20 pounds of weight) whilst improving weight distribution.
Old 11-15-2020, 12:52 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #160 (permalink)
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
