-   -   Swapping 150mph speedo for a 85 mph sppedo (http://forums.pelicanparts.com/porsche-911-technical-forum/897248-swapping-150mph-speedo-85-mph-sppedo.html)
Starless 01-04-2016 07:17 AM
When I bought my car the PO had replaced the USA 85mph speedo with a 150mph unit. Well I need to send out the 150 unit to get my odo fixed. When I put in the 85 mph unit in is it a straight swap, or do I need do do something to have it read properly? Also, does it matter in which holes I put which light bulbs in?
Algernon 01-04-2016 07:28 AM
It is a straight swap, as long as you don't miss-connect the wires. Hardest part is getting speedo out/in.
Starless 01-04-2016 07:31 AM
Thanks, I've had the speedo out once before to reset oxygen sensor light.
