Wayne, what's up with the B&B front mounted oil cooler availability?
I called only to discover that Pelican doesn't carry the B&B front mounted oil cooler (?) I could have sworn several posters said they picked it up from PP. I thought it would be a good time with the holiday special.
Old 12-05-2002, 01:08 PM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
Please call me back
The B+B Are available give me a call back And I can Supply it for you.Steve@pelicanparts
B&B Tri-Flo Cooler Kits
These cast aluminum oil coolers are excellent upgrades for your standard 911 oil cooler. The radiator fin coolers are manufactured out of alumnium, and will reduce the operating temperature of your engine greater than the standard fender-mounted trombone oil cooler. The fender-mounted cooler comes complete with electric fan that can be turned on automatically (based on oil temperatures), or with a manually operated switch. The front spoiler-mounted cooler is designed for use with race cars having an aftermarket spolier with an oil cooler cutout in the front. Both coolers are constructed out of cast aluminum, CNC-machined for precision, and then arc-welded for super-tough construction. Both make a great alternative to the standard Porsche Carrera Oil Cooler. Both coolers contain attachment lines and mounting hardware to attach to cars already equipped with front-fender mounted oil coolers. Cars without front-mounted oil coolers will need to install the oil lines and thermostat that run up the underside of the car.
B&B 911/911 Turbo Front Mounted Oil Cooler Kit [Photo]
PEL-BBKT3 $715.00
B&B 911/911 Turbo Fender-Mounted Front Mounted Oil Cooler Kit w/fan [Photo]
PEL-BBKT4 $845.00
Old 12-05-2002, 01:48 PM
Thanks. I will.
Old 12-05-2002, 02:31 PM
