Oil drain plug --- same for oil tank, engine case
Looking for parts for oil change -- 83 SC.
This looks to be the part for 83 SC. Is it same for both oil tank and the engine case plugs?
1983 Porsche 911 SC Coupe - Filters & Belts - Page 2
Thanks!
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 01-28-2016, 11:39 AM
VFR750's Avatar
If you have an early 83 with a sump plate, then yes they are identical.
The late 83 case without the sump plate may use the same one. I am not sure
Old 01-28-2016, 01:13 PM
VFR750's Avatar
If you have a late 83 without the sump plate, just look at an 84 Carrera.
Yes there is a different plug part number for the case.
Old 01-28-2016, 01:42 PM
