Central Locking Control Module - Board Help.
Trying to tackle central locking issue (not working). This is part 91161811301 out of an 89 911 3.2. If anyone has a pic or a unit about, could you please post a picture of the board. A friend noticed an apparent solder break. Not sure what this is, but it doesn't look right. This may be a Hail Mary, but worth a try. Thanks.
Board with potential issue. http://forums.pelicanparts.com/uploa...1452652725.jpg Close up http://forums.pelicanparts.com/uploa...1452652769.jpg |
Very common break, your friend is right, solder that piece back and I bet your system will work properly
Thanks for your response 964TargaC2. You happen to know what it is. Not critically important but just curious. I'll clean it up and solder it and give it a try then post the result. Thanks, Paul
know this is an old post.. but did the soldering work?! i’m have an issue with my locking system as well. it works perfectly then doesn’t periodically. like to know what your exact symptoms were, like to tell you mine.
Mine had the same break, I soldered and it worked!!! Thanks
Central locking.
Yes, cold solder joints can be very elusive.
Hope this helps. Best, Gerry http://forums.pelicanparts.com/uploa...1669562688.jpg http://forums.pelicanparts.com/uploa...1669562688.jpg http://forums.pelicanparts.com/uploa...1669562688.jpg http://forums.pelicanparts.com/uploa...1669562688.jpg http://forums.pelicanparts.com/uploa...1669562688.jpg |
| All times are GMT -8. The time now is 04:19 PM. |
