BBS Wheel sizing
Will BBS RS wheels off an 1988 944 turbo fit an 1989 911 Carrera?
The numbers from inside the rims are as follows: 7J x 16HZ ET 49 RS 157 8J x 16H2 ET 49 RS 158 I would like to use these without the need of spacers. TJC 89Cab |
offsets
If it's an 89 and not a C2 the offsets or ET are:
Fronts 23 Rear 10.6 You will need spacers to take up the difference on those wheels. If you are going to use a spacer, the smaller the better...they can put stress on the wheel bearings if they are to large. The front offset requires a 26mm spacer the rear a 38mm spacer. To much IMHO. |
| All times are GMT -8. The time now is 11:00 AM. |
