-   -   1987 headlamp switch illumination? (http://forums.pelicanparts.com/porsche-911-technical-forum/898728-1987-headlamp-switch-illumination.html)
Slanski62 01-15-2016 12:29 PM
My headlamp switch doesn't light up. From what I can tell in the Haynes manual, there isn't a bulb, but I want to make sure. If someone would confirm, I would appreciate it?
SOAZ 01-15-2016 01:35 PM
My headlight switch doesn't light up, but my foglights switch does. 1988 Coupe.
ganun 01-15-2016 01:36 PM
I wondered about that too on my 87, but it seems that the HL switch is not lit.
Slanski62 01-15-2016 02:12 PM
Thanks SOAZ and ganun. That's how mine behaves.
mark4ton 06-05-2016 09:58 PM
no light in there. you can pop the little plastic cap/ headlight sign with a small screwdriver or pick, all you will find is a 10mm screw holding the knob in place
DRACO A5OG 06-06-2016 12:06 AM
Nope, not on my buddies' 87 or 88
Canada Kev 06-07-2016 08:34 AM
No light. Under the little plastic cap is the nut that holds the switch in place on your dash.
