911 '87 Headlight fused relay bracket replacement
Hi all,
I found this molten fused bracket in my head light array. It fits a 5-pin relay. There is no brand, nor parts number on it.
I want to replace the molten bracket with fuse, but according to my local parts dealer 5-pin relay brackets with fuse are no longer available, only 4-pin relays with fuse ???
The 5 pins and the 2 fuse pins have wires attached (7 in total).
What are my options ?
Many thanks for your replies.
Kurt
Old 01-18-2016, 12:45 AM
geoz's Avatar
I don't think this is factory, looks like the jwest solution. I can't remember how many wires that has, you should be able to find out, but I think it is 4. If you want to fuse it you could wire an inline fuse between the battery and the relay.
Sent from my SGP321 using Tapatalk
cheers
hg
1988 911 Cabrio
Old 01-18-2016, 01:51 AM
