??82SC rotor/distributor "post" ??
I pulled off my rotor on my 82 SC and the top of the distributor post is rusted and the felt pad in the center of the post is dry. I thought that the felt pad is to be oiled from time to time and that in some way lubricates the vac. advance in the distributor??
Please enlighten!!
Old 12-06-2002, 06:37 AM
Early_S_Man's Avatar
Porsche Crest
The cam and central drive shaft for the centrifugal advance is what needs lubricating under the felt!
distributor lube...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 12-06-2002, 06:50 AM
Senior Member
Jdub's Avatar
Ideally you would strip and clean your dist.
However, a bit of machine oil or the like may help free up the plates and springs that make up the advance mechanism. You may be pleasantly surprised to find a quicker back-to-idle at stops and smoother idle generally.
But that is just conjecture on my part. My experience was that there was a BUNCH of old grease and particulates in the body of the dist. and cleaning the unit really made a difference for both smoother idle and takeoff (or was it in my mind?).
John
'78 Targa in Minerva Blue
Old 12-06-2002, 06:56 AM
