Keep the SC.
Old 01-28-2016, 10:30 AM
Well a new contender has entered the ring. I might have to hand in my PCA membership card but I've been eyeing up '96-'02 Dodge Vipers. I'm pretty sure it's a bad idea but that's kind of the draw. It'll probably all go away the first time I climb back into my SC.... maybe.....hopefully?.....i need to be saved I think.
1980 911 SC - Black on Red
Chronicles of my '80 SC: http://forums.pelicanparts.com/porsche-911-technical-forum/844949-chronicles-my-80-911-sc-91a0140491.html
Old 01-28-2016, 01:08 PM
Deschodt's Avatar
No personal experience. A guy at the track complained his feet were burning after driving his (for real, he has red skin)... and the bodyshop guys that restored my 911T also worked on one of these Vipers around the same time and said that, bar none, that was the $hittiest car they ever ever ever worked on ;-) (quality of components, plastics, gaps, from memory). Not that this should kill your dream, we only live once!
Old 01-28-2016, 01:18 PM
flat6pilot's Avatar
1- yes
2- no
3- yes
Just turbo your SC:
https://www.youtube.com/watch?v=KuxlJwS0s-M
Kyle - 1980 RoW non-sunroof 911sc - 3.2 Turbo, Mahle P&C, Carrillo Rods, Megasquirt II (Fuel Only for now), re-geared 3rd and 4th 930 gearbox, 2350lbs
Old 01-28-2016, 02:42 PM
wayner's Avatar
Cost of tires and brakes for track days in a viper???
Do more track days in your SC and you won't ever want to get out of it. You need more bonding time.
Stay away from road courses that feel like drag strips
SOLD - 914 wide body hot rod
Old 01-28-2016, 02:44 PM
gruppe f
mikehinton's Avatar
An older Viper is going to feel like a truck compared to your SC. Like many others have said, keep your SC, learn to drive it to its (or your) limits, and then consider something else.
Mike Hinton
'06 Cayman S Carmon Red, '05 Cayenne Turbo Black, '87 Carrera Granite Green, '72 911T Aubergine,
'74 914 1.8 Marathon Blue, '64 356C Aubergine
Old 01-29-2016, 09:40 AM
Better in Person
juanbenae's Avatar
I would consider an early z06 corvette long before a viper.
Old 01-29-2016, 10:02 AM
PhD on Pending Projects
wachuko's Avatar
Send a message via AIM to wachuko Send a message via Yahoo to wachuko
A Viper??!!! Yuk! I have driven a few... no frigging way... the reference to driving a truck is spot on... driver position, pedals, shifter... man! everything is wrong about them...
If you want speed... then go with the 996TT.... not a Viper!
Drive safe!
1967 - Porsche 912
1981 - Porsche 911 SC
1991 - Porsche 911 C4 Wide-body Cabriolet
Troll Hunter
A viper? Come guys, let's grab the torches and the pitch forks!
Sent from my SAMSUNG-SGH-I337 using Tapatalk
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 01-29-2016, 10:16 AM
wachuko's Avatar
+1... a C5 Z06 would be much better than a Viper... still... if what the OP wants is something different... then just go with the 996TT
Seems he has the itch for a change... got to scratch it. Just do not make the mistake of getting into a Viper... you have been warned.
Drive safe!
1967 - Porsche 912
Old 01-29-2016, 10:31 AM
I did some soul searching last night and decided I'm really a Porsche guy.
And also as someone mentioned I do have an itch. I think the biggest contributor is I want to get out on the track safely. I am having the car checked out by a pro to make sure I didn't miss anything but I'm fearful of some brittle CIS part braking on me or even worse an engine failure.
I started looking at 987.1 Cayman S however that still has the IMS issue and the 987.2 cars are much more money.
I think we can let this thread die now, I appreciate all the input. I will not be purchasing a 996tt (and probably not a Viper). If anything happens it'll be to another Porsche.
Old 01-29-2016, 11:59 AM
wayner's Avatar
The good news is that now you are stuck with one of the most bullet-proof engines that Porsche has ever made
Old 01-29-2016, 12:14 PM
wachuko's Avatar
If this is the case... then please... got for a 996TT... those cars are pretty bullet proof... just the precaution of the coolant hoses that was mentioned and you are done. And have a spare accumulator...
In terms of depreciation, they have pretty much reached bottom, so most likely you will not loose any $ when you decide to sell it. And those are THE 996 to buy/own (engine that go back to the racing cars, etc.)
Drive safe!
1967 - Porsche 912
Old 01-29-2016, 12:46 PM
This is up to the Porsche forum Gods.. It may live on as a constant reminder of your urge to trade your SC in for a Viper
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C
Old 01-29-2016, 12:50 PM
Alan L's Avatar
The SC is a strong car/engine. You will give up on the track before it does.
Alan
83 SC, 82 930 (track) - Stock except for RarlyL8 race headers, RarlyL8 Zork, K27-7006, 22/28 T bars, 007 Fuel head, short 3&4 gears, NGK AFR, Greddy EBC (on the slippery slope), Wevo engine mounts, ERP rear camber adjust and mono balls, Tarret front monoball camber adjust, Elgin cams, 38mm ported heads, 964 IC. 380rwhp @ 0.8bar Apart from above, bone stock:-)
Old 01-29-2016, 01:11 PM
gliding_serpent's Avatar
A original viper gts has always been a childhood dream of mine (second to a 911). Maybe i need to drive one to put it to rest. I figured the red hot sidewells and cabin that smells of glue when you drive would be endearing. But i like oddball cars.
And the new viper is one of the hottest looking cars on the road.
1997 BMW M3 (race car) with S54 engine swap "The Rocket"
1984 Porsche 911 3.4 Carrera
1973 BMW 2002Tii
2016 Ford Focus RS
Old 01-29-2016, 01:20 PM
Troll Hunter
Think of all the money you're going to save on gold chains and cologne now that you're not buying a Viper!
1988 FJ62 Blue/Gray
2020 M2 CS
Old 01-29-2016, 02:01 PM
Kraftwerk's Avatar
For the price of a 3.6 transplant in the SC you could have a very nice Spec Miata. track ready.
As far as a bad interior on a 996 TT you could cage it / gut it and it wouldn't bother you anymore.
I don't even know what a Viper is, but glad you passed on that..
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 01-29-2016, 02:18 PM
Eng-o-neer
Tremelune's Avatar
Put me on the list if you sell the SC. I'd love a non-original widebody in black.
Old 01-31-2016, 04:19 PM
