-   -   Help with trailing arm thread (http://forums.pelicanparts.com/porsche-911-technical-forum/900125-help-trailing-arm-thread.html)
lylejenks 01-26-2016 07:00 PM
Might have made a stupid, fatal error late last night on my 1980 911SC. :mad:
I was reconnecting the rear driver-side shock to the trailing arm last night with an impact wrench, and I'm pretty sure I shredded the threads inside the trailing arm (and the threads on the bolt as well).
Is there anything I can do short of replacing the entire trailing arm?
Images of the trailing arm threads and the bolt below:
http://forums.pelicanparts.com/uploa...1453863339.jpg
http://forums.pelicanparts.com/uploa...1453863362.jpg
rusnak 01-26-2016 07:03 PM
Time-sert?
lylejenks 01-26-2016 07:28 PM
Originally Posted by rusnak (Post 8973352)
Time-sert?
Have never heard of Time-sert. Just googled and looking on the site now. Any experience with them?
chris_seven 01-26-2016 07:31 PM
Helicoil Kit is cheaper and uses the same tap as a Timesert and for this application is probably OK.
Alan L 01-26-2016 08:31 PM
Either will be fine. Hopefully you have not destroyed too much interior to allow decent tap for above. Not fatal, and the insert will be stronger.
Lesson learned - hand tight EVERYTHING at least a few threads before taking a tool to it.
Alan
