What Kind of Paint?
What kind (not brand) of paint did the factory use on my Guards Red '88 Carrera? It is in excellent condition. Lots of evidence suggests that POs kept the car out of the sun's UV at home and at work. I am curious as to what kind of paint the factory was using in the late 80s.
Old 01-31-2016, 08:37 AM
Justin@Athens's Avatar
Send a message via AIM to Justin@Athens
Glasurit, single stage, non metallic. Oil based. NLA due to EPA restrictions. Now pretty much everything is base/clear coat. But some single stage acrylics are still available. 22-line
1990 964 C4 Coupe & 1991 964 C2 Coupe (current)
1989 911 Targa (sold)
1996 993 Cab. (sold)
1999 x2 Boxster (sold)
2006 Cayman S (my daily)
Old 01-31-2016, 09:56 AM
onboost's Avatar
Base/clear has been around for quite sometime.. and not due to EPA as in some states its still available in solvent based. I think what you meant was water based "base"/clear coat is more prevalent now due to EPA restrictions.
Yes, some single stage acrylics are still available. I like using those on chassis, trunk and engine areas.
RGruppe #180
Old 01-31-2016, 11:07 AM
djpateman's Avatar
Do you have the original full paint code: xxx-y-z The manufacturer is coded there.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 01-31-2016, 11:36 AM
famoroso's Avatar
When did 911 production switch from oil based to water based?
Old 02-01-2016, 06:12 AM
onboost's Avatar
That's a good question as many companies switched before the big push for it but never really said anything about it.
I really don't even remember seeing or hearing of service bulletins regarding this.
The big misnomer in all of this is that the previous paint isn't oil based.. its solvent based. And the only thing water based at this point is the actual base coat! The primers and the clears are still solvent based.
RGruppe #180
Old 02-01-2016, 06:35 AM
