kmoush's Avatar
Tire OD sizes for 15" Fuchs. What are your thoughts?
Looking for your thoughts.
I recently purchased my 86 Carrera coupe. The car came with 15" 7 and 8s. The tires that came on the car are 205/50R15 and 215/60R15. Yes, the ODs 23.08 and 25.17 respectively. The previous owner did lower the front end a bit to compensate for the smaller diameter.
Now that the tires are worn I am looking to replace them with Falken Ziex 329, in the same size currently on the car SINCE the car does handle well in this size configuration and on hard cornering I don't get that spongy feeling that most people complain of when they use a 60 or 65 on the front.
I was considering replacing the fronts with 205/65 (60s are not available) but the OD for that tire 25.44" and the original size of 195/65 has OD of 25.04". However I am concerned that using a 65 on the front will result in too soft a response on hard cornering. I am curious which of the two, tires with similar front and rear OD or reduced sidewall, is more critical. Or is it a matter of preference?
A couple of things to keep in mind. I plan to drive the car as a DD and do road trips, so primarily highway and spirited twisties. I am also considering doing some AX and a DE events, maybe 2 or 3 a year, knowing these are not the ideal tires or sizes for these events. Purchase of 16" wheels will happen in a year or so once I have more storage space and sort out all the mechanicals of the car in the meantime. So these new tires are to hold me over til then.
Old 02-07-2016, 08:24 PM
Mick_D's Avatar
if this is just a holdover purchase it probably isn 't worth worrying about. experience with the issue is worth more than advice if there is little downside.
Old 02-08-2016, 08:21 AM
