-   -   Need help finding a part number (http://forums.pelicanparts.com/porsche-911-technical-forum/900887-need-help-finding-part-number.html)
gsxrken 02-01-2016 03:33 PM
Seems like it would be easy, but I cannot find the part number for two rubber grommets for the wiring harness that goes through the tub from the trunk to the passenger compartment. 1986 911 turbo
You can see the two holes here that need a rubber insulator so the wires don't chafe on the sheet metal:
https://lh3.googleusercontent.com/et...z=w942-h706-no
sugarwood 02-01-2016 05:12 PM
Is it on p.404 (KAT 507) of PET ?
#29 is 91161286300
Same part number also shows up on p.415 (KAT 507)
universeman 02-02-2016 05:57 AM
On my 82, that one on the left is a female pigtail connector, not just a grommet. Check inside passenger footwell for male side. My 82 has nothing in the right holes except aftermarket speaker and radio wires.
gsxrken 02-05-2016 09:02 AM
Thanks for the replies. Sugar wood, I don't know if that's the part but it appears to be NLA in either case.
I'll try hardware store for generic grommet or plug and make opening for wire harness.
