-   -   How to run wiring from engine compartment into cab? (http://forums.pelicanparts.com/porsche-911-technical-forum/901024-how-run-wiring-engine-compartment-into-cab.html)
hawaii83cab 02-02-2016 05:02 PM
I'm installing a AEM wideband 02 in my 83 Cab. I have the sensor mounted and the wiring run into the left side of the engine compartment. Is there an easy way to get the wiring into the cab without drilling?
patz 02-02-2016 05:13 PM
Should be a hole already there, look under the carpet in front of the rear seat. Should be a hole with a rubber grommet for the engine harness.
dos531 02-02-2016 05:22 PM
Your car is earlier so it might be different, but there should be a couple different ways in. I used a hole at the front left of the engine compartment where the harness goes into the cabin.
DRACO A5OG 02-02-2016 05:25 PM
Follow the defrost wires on the rear window, that was the hole I used for my Third brake light install
hawaii83cab 02-02-2016 05:44 PM
I don't have defrost wires, it's a Cab.
hawaii83cab 02-02-2016 05:49 PM
I don't believe the earlier cars have this access hole. I was looking in that exact location for a while and couldn't figure out how to get it through. With it being cab there's probably a difference in the firewall/rear seat area. I'm guessing a coupe would be easier to get into the passenger compartment.
patz 02-02-2016 05:55 PM
Joe Bob has an 83 cab, same hole.
JohnJL 02-02-2016 06:24 PM
Plenty of holes through the transmission tunnel. Reroute the sensor down low and go in through the ~12 holes with grommets there.
Reiver 02-02-2016 07:18 PM
I ran my sensor wire ('83 SC Coupe) thru the central tunnel by attaching a stiff wire (bailing wire) to the end then running the wire thru the opening near the tranny coupling where the electric wire for the tach runs.
You can fish it out/assist it thru the many access points in the tunnel.
I had it come out near the front floorboard then drilled an opening large enough for the plastic connectors on the bottom side of the dash under the clock (where I mounted the guage)...I had just enough unit wire for that to work and it was tight but have had no issues for a few years now.
I think, for a CIS car, an afr gauge is a requirement...huge tuning tool.
hawaii83cab 02-02-2016 07:34 PM
Ahh so don't bother going through the engine compartment then.. Looks like the way your describing will be easier..
hawaii83cab 02-02-2016 07:36 PM
I will probably end up doing a version of this..
hawaii83cab 02-02-2016 08:35 PM
Thank you to everyone who helped. I ran it through where the shifter coupling is and all went well. I don't know why I had it in my head that I was going to take it through the engine compartment. I hope this helps someone else in the future.
James Brown 02-02-2016 08:41 PM
i would use a bulkhead connector cannon plug
http://forums.pelicanparts.com/uploa...1454474387.jpg
and a male plug on the cabin side
http://forums.pelicanparts.com/uploa...1454474438.jpg
fluid and flame tight plug
rnln 02-02-2016 11:43 PM
My car, there is a bundle of wires run from front along the left side step through the chassis behind (on the left) the seat, then go up to engine bay from there (behind the rear torsion tube).
