beamonk's Avatar
Send a message via AIM to beamonk
blew oil line!
I was running with spirit this morning and blew the line from the engine oil cooler to the thermostat. I have been having high pressure 140 psi and very cool temps, well less than 180, I suspected the thermostat was not working, staying open letting oil continously go the the radiator in the front. I let it idle and checked the lines, it was warm as it was after a long drive, but not hot. Today, the line seperated from the connection. Hopefully pulled it over soon enough to prevent damage. I pulled the fender thermo. apart and a piece of fiber was broken on the small plunger. I would imagine i need to replace the thermo. in the fender, but what else should I do? Pressure is too high and I don't want this happening again. 76 with an 83 3.0 front radiator cooler.
Thanks,
John
John Brasfield
91 C2
78 SC For sale
76 3.6
68 Datsun 2000 Mr. Magoo, 02 330ci
Old 12-01-2002, 12:10 PM
Rouxzy's Avatar
There are two things you need to check in the side thermostat. From what I understand you have the thermostat under one screw cap and then you have a pressure limiter, (plunger) in another. You need to make sure you have the right one for the right year.
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 12-01-2002, 03:19 PM
is your pressure release piston(s) stuck in the block. 140 psi?
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 12-01-2002, 03:53 PM
beamonk's Avatar
Not sure if it is stuck in the block or not, I will check it tomorrow hopefully, but it is the girlfriends birthday..... Maybe Tuesday, I hope it is only the thermostat and the pressure relief, don't want to operate on top!
John Brasfield
91 C2
78 SC For sale
76 3.6
Old 12-01-2002, 08:43 PM
beamonk's Avatar
Well, I think I got it fixed. The aux. thermostat was replaced, blown line replaced, the pressure sender was for a Euro model, put my old 2.7 one in. Even fixed the axle that had a blown boot. I checked the relief valve, it was cool. Now the pressure is 20 at idle and up to about 70-80 psi running hard, the temp has stayed up to 180 around town. I hope this is the fix, that was pretty scary, but the motor feels good and undamaged. I guess the thermostat was stuck open and it never let the oil get warm, which made the pressure higher. I put 10w-40 in it and will put 20-50 or something this spring. Good to have him back!
John
Doesn't leak now, or, should I say, for now!
John Brasfield
91 C2
78 SC For sale
76 3.6
Old 12-08-2002, 12:27 PM
