 Dash lights & Switch My interior dash lights (these are LED’s) have recently started to annoyingly constantly flicker. First it was just the one bulb now several are doing it, by adjusting the dimmer setting they stop for a while then start flickering again. Now I assume it’s the 30 year old dimmer circuitry that’s now malfunctioning and a new switch is in order. As I always have all my cars dash lights set to maximum, I don’t care for or need the dimmer option. Is there just a simply Porsche "on off" replacement switch that can be purchased or do I need to decommission the dimmer function on a new or on the old switch for that matter or can the dimmer element be by passed? Regards |
 Interesting - the "dimmer" is just a variable resistor in the switch. Is the flickering "constant" (meaning equal time on/off) or "intermittent" (meaning there is no discernible pattern to the flicker)? |
 You could remove the switch, marking all the wires and inspect the rheostat. But before that I would check all the grounds to insure they nice and free from corrosion. If you have not do so, I would install a inline fuse as the black/blue wire is not fused. |
 try dousing the rheostat dimmer switch with electrical contact spray before doing anything else...it's probably just dirty. |
 If you want to bypass the rheostat just move the black/blue wire over to the grey wire terminal for the running lamps. You can look up the terminal number for your year to confirm. Fusing is always a good idea. |
 N - Grey/White 58l - 2 x Grey/Black 58r - 2 x Grey/Red 75 - 2 x Red/White 57 - White/Green 58a - Red in line fuse and then to the Blue/Black from the loom 58 - 2 x Grey 56 - White/Black So move 58a to 58, what do I do with the grey wire just tape that up? |
 Light switch. http://forums.pelicanparts.com/uploa...1454922149.jpg ^^^^^ For our '86. Hope this helps. Good luck, Gerry |
 Should have a female spade with a male tab available on your wire. If not install one. Then just double it up keeping the license lamps in the circuit as well. |
 Just a little concerned as I don't want to end up with fried wiring!:confused::( |
 Led lamp load is what? Current load on that cicuit now is 2 incandescent lamps. Pretty negligible added together... The load of the dash lights is already going through the switch, just on a different contact. Your only other alternative is repair or replace the switch. Pop a couple of led lamps in the license plate holders and you'll be fine... |
 Thanks in advance |
 So did this and still had some flickering, so can only assume its a dodgy connection or a faulty relay (if this is one!) |
 Did the cleaning or moved the source wire? If still flickering I am thinking it may be a ground issue. |
 Are you sure the LEDs are dimmable? Many aren't. |
 They have been working fine for several years, only stared flicking a few months ago, Thinking about it I noticed the flicking after the car was laid up in the garage for a few weeks |
| All times are GMT -8. The time now is 09:30 PM. |
