Alternator / starter / EFI wiring help
converting my 79sc 3.0 to EFI and looking for some verification with wiring.
I just received my new Alternator which is INTERNALLY regulated. Stock Alternator has 1. Large red / small red wire 2. black wire 3. blue wire 4. 3 brown wires 5. 1 brown wire to engine case Since this is internally regulated, I am assuming I just leave the Black , Blue, and one brown wire out of harness. There is only two studs on new Alternator. I am assuming 3- gets brown wire to engine case and 3+ gets red wires http://forums.pelicanparts.com/uploa...1455060517.jpg The starter has three wires 1. Thick yellow 2. thin yellow 3. large red I believe the thin yellow with blue strip goes to cold start injector? Thick yellow is to fuel pump relay can someone please confirm |
Only the black wire DF is not used.
Thin yellow can be deleted. |
DF? Sorry English please. I am not good with electronic stuff.
I followed the wires from alternator and the black, blue, and brown wire all run into the voltage regulator. |
DF is the designation on the prints for the feed to the voltage regulator.
You can delete a lot of wiring in the '79 engine harness depending on what EFI system you are installing. Give more details and I can give you guidance as I've built a lot of custom engine harnesses for people.
I see 3 studs on your alternator. One for reds, one for Blue and one for ground.
PM me your phone number and a time to call and I can talk you through the alternator and the wiring for your engine harness. (I'm on the west coast for time considerations) |
| All times are GMT -8. The time now is 05:33 AM. |
