Send a message via AIM to Nickalex86
Question Lowering front??
Can someone please explain to me how to lower the front end of my '70 t? Perhaps someone can link me to a site with pictures, or anything like that which would help. It just looks awkwardly high compared to the rear end. Thanks a lot.
Nick
Old 12-09-2002, 04:15 PM
Senior Member
Superman's Avatar
Between the front wheels, about a foot toward the center of the car, there is a 13mm (I think) bolt head that sticks down. Turning it raises or lowers the front.
Mocha 1978 911SC. "Coco"
Old 12-09-2002, 04:39 PM
tobluforu's Avatar
Get car aligned after. Also you will want to do this on flat ground. After lowering both sides to what you think looks right, drive car around block a few times. Park car in same spot and check height again. Takes a few turns to get right. You may want to dis-connect sway bar if you have one.
Old 12-09-2002, 04:43 PM
Thanks fellas!
Old 12-09-2002, 05:05 PM
