Sunroof Drain Cleanout
How do you blow out the sunroof drains can't even find the holes front windshield seal replaced and now for the rear, want to make sure it is not the sunroof leaking as well thanks
Old 04-17-2017, 04:17 PM
911SC Tinkerer
merlinfe's Avatar
I've seen people get pipe cleaners and link them together very well to push/pull debris out. This worked for me on two of my sunroof cars (both non 911). You could always go through the bottom under the deck lid for the rear. It may even help you locate the holes.
If that doesn't sound cool, I'd look at where the holes are in the Porsche PET Katalog online. Just look up your year.
-Steve
-'83 911SC Coupe
SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc
Old 04-17-2017, 05:21 PM
For an SC w sunroof panel out youcan see where the drain holes are. Cannot imagine finding ot w roof panel installed, whether open/closed
1983 911 SC Coupe w Sunroof, Metallic Silver --- AKA 83 Silberpfeil
Old 04-17-2017, 05:56 PM
Senior Member
Jdub's Avatar
Use weed whacker line - 8mm or smaller and have a hose with a low volume of water. From the bottom, use a coat hanger for the first 3 - 5 inches since that is where most of it lives. Next, use the line to plumb the tube free of dirt from the top, taking your time so as not to pack anything.
This has served me very well on old Mercedes sunroofs.
'78 Targa in Minerva Blue
Old 04-17-2017, 06:32 PM
Flexible emergency brake cable also works. As the poster above noted, go slow.
____________
Jim
82 930
Old 04-18-2017, 05:49 AM
Administrator
Luccia at Pelican Parts's Avatar
Some pretty good pictures in this Pelican thread here: So, where is this infamous sunroof drain?. Maybe see if it may be helpful to you.
Old 04-18-2017, 08:32 AM
Functionista
manbridge 74's Avatar
A long piece of allthread around 1/8" works well. Helps to have a rag under upper end to catch debris.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 04-18-2017, 11:15 AM
Thanks gentlemen !!!! I had no idea ... looks easy enough ... all the thread connections surely identify the issues ...thanks again
Old 04-18-2017, 04:24 PM
