ischmitz's Avatar
Send a message via Skype™ to ischmitz
Angry Rocker trim rubber
How do I get the rubber trim back on to the side rocker pannels?
Trying to slide it I get stuck at 10 inches at the most. Any good ideas out there??
ingo
Old 12-10-2002, 09:51 AM
Randy Webb's Avatar
use rubber lube or soad solution or WD-40
etc. and use needle nose pliers to grab and pull -- it's a *****.
Old 12-10-2002, 09:55 AM
Recreational Mechanic
Nickshu's Avatar
Its a PITA! I lubed mine up with soapy water. This helped and combined with needlenose pliers it only took 30 minutes per side
Nick.
P Cars: 2022 Macan GTS / One empty garage space ---- Other cars: 2019 Golf R 6MT / 2021 F-250 Diesel / 2024 Toyota GR86 6MT ---- Gone: 1997 Spec Boxster Race Car, 2020 GT4, 2004 GT3, 2003 Carrera, 1982 911SC, 2005 Lotus Elise and lots of other non-Porsches
PCA National DE Instructor #202106053 / PCA Club Racing / WRL Endurance Racing
Old 12-10-2002, 09:57 AM
johnnyo200's Avatar
Ditto- soapy water or my favorite, Silicon Spray
Took me a max of 5 min. per side.
johnnyo200
'84 911 Targa Carrera
Old 12-10-2002, 10:09 AM
I can do this in <2 min.
The procedure is in the factory repair manual. Intuitively, you want to slide in on, but friction will stop you well short. The recommended method is to bend the rubber back almost 180 degrees. This spreads open the rubber as you install it onto the rails of the rocker panel. Spray some silicone on the rubber and rocker, then begin installation from the tail end of the rubber.
Hope this helps,
Sherwood Lee
http://members.rennlist.org/911pcars
Early 911S Registry
Old 12-10-2002, 10:50 AM
johnnyo200's Avatar
Well, it was during a blackout, yeah, and I was looking at it through the reflection in mirror, yeah that's it, and I was wearing mittens....
johnnyo200
Old 12-10-2002, 10:56 AM
avi8torny's Avatar
Send a message via AIM to avi8torny
A product called SIL-GLIDE is made just for this. It is referred to in the Bentley manual and you can pick it up at any well stocked auto store. It will make it a simple job.
12' GT3
18’ 991S
Old 12-10-2002, 01:14 PM
buttjoint's Avatar
I used regular ol dish soap straight out of the bottle
Old 12-10-2002, 02:25 PM
