cashman's Avatar
Elephant Racing Camber Plate install
Can anyone post some good pictures of the Elephant Racing Camber Plate installation. I have found several using the adjustable plate but not too many using the fixed offset plate. Pretty sure I understand the order of installation but I would like some verification. Thank you.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 02-21-2016, 12:21 PM
BFT3.2's Avatar
Here's a few photos from when I installed mine. A couple things to note, the plates are not symmetrical, you can use either plate on either side but one will make available more negative camber then the other. It wasn't needed but I also installed the thin stock washer that is normally bent up to prevent the stock strut nut from unthreading. The nylock nut in the Elephant kit negates that need but no harm in doing it either. Hope the photos help.
______________
'88 911 Coupe
'98 Spec Boxster
'85 380SL Benz -Euro
Old 02-21-2016, 04:24 PM
cashman's Avatar
Cant imagine it gets any better than that.
Thank you.
Old 02-21-2016, 05:11 PM
BFT3.2's Avatar
Glad I could help.
______________
'88 911 Coupe
'98 Spec Boxster
Old 02-21-2016, 05:45 PM
