-   -   MSD part numbers (http://forums.pelicanparts.com/porsche-911-technical-forum/903524-msd-part-numbers.html)
RyanH 02-23-2016 01:09 AM
MSD part numbers
Hi all. When fitting an MSD, 101 Projects recommends the 6420 model. I have the opportunity of a 6200, is this an inferior model and not suitable for a 1970 911? My car is an everyday road car not a track car. Cheers
timmy2 02-23-2016 07:55 AM
MSD Streetfire is a newer unit at a low price that people are having good results with.
Pazuzu 02-23-2016 08:53 AM
6200 and 6420 are no longer supported, but work fine if you find one.
6201 and 6425 are the new versions, slightly smaller and with a better cabling system.
The 6200/6201 are the "6A" version, the 6420/6425 are the "6AL" vesion.
6200/6201 have no rev limiter. 6240/6425 have a rev limiter. Nice to have that...
Streetfire 5520 is smaller and lower powered, but still plenty for any stock aircooled 911. Much smaller than the 6A/AL, rev limiter, solid state electronics (might survive heat and vibration better?) and black instead of red.
6421 is the 6AL with a a dual stage rev limited (launch control), 6530 is the 6AL with programmable advance control.
RyanH 02-23-2016 12:40 PM
great response thank you, might go the Streetfire after all. Same tach adaptor?
