Calspeed's Avatar
Weak Washer Pump
Hello,
Just drove my car back from its first snow excursion and the washer pump just didnt want to pump water. The system worked just prior to the trip.
Do these pumps wear out frequently?
Calspeed
Old 12-09-2002, 07:59 PM
Friend of Warren
One of the cool things about the washer pump is that you can actually take it apart to be cleaned if it is all gunked up. Just be careful not to tear the gasket. In your case you might want to check and see if the washer nozzles are plugged up.
Kurt V
Old 12-10-2002, 07:31 AM
