falcon's Avatar
Post Big G50 Growl
Since I purchased the car 5 months ago, I've always has a slight growl (not grind) AFTER I am in first gear and accelerating. The growl only happens once in a while. There was a post about 2-3 weeks about growling, it appears a slight growl is normal. I looked over the PO maintenance record and did not see a transmission oil change so I decided to change it.
Oil removed was dark I refilled the tranny with Mobil 1. Started her up and took it for a ride to see if I can notice a difference. The difference is that it growls LOUDER and for a longer duration. Drove the car a few miles but not high revving or at highway speeds. The sound only happens off the line.
Any one experience this? Am I using the "right" transmission fluid?
Randall
'88 911 Cab
Old 10-09-2001, 09:58 AM
Rick Lee's Avatar
Post
I've heard that when you switch to a synthetic oil, you should run it for 1000 miles and then change it again. Supposedly, a new, synthetic oil will collect whatever particles are left in there. So it's good to give it another flush.
Old 10-09-2001, 10:17 AM
Post
the factory had a bulletin where they installed a rod from the side of the trans to one of the heat exchangers to transfer the noise. G50s do have normal gear rattle at various low rpm, low load situations.
Old 10-09-2001, 10:20 AM
falcon's Avatar
Post
John or anyone have the bulletine or know where I can take a peek at one of these rods?
Randall
'88 911 Cab
Old 10-09-2001, 12:42 PM
