-   -   Copper color Fuchs...good or bad? (http://forums.pelicanparts.com/porsche-911-technical-forum/904179-copper-color-fuchs-good-bad.html)
garrett490 02-28-2016 01:34 PM
Not sure if I like this color or not. Your thoughts?
http://uploads.tapatalk-cdn.com/2016...62778cc659.jpghttp://uploads.tapatalk-cdn.com/2016...461cdabd4e.jpg
grizzfan 02-28-2016 01:47 PM
To each his own. For my part: "Yuck"!!
Tom
Jp-oh 02-28-2016 02:02 PM
I like them but like it better when there issome black and the copper is more brassyhttp://forums.pelicanparts.com/uploa...1456700538.jpg
garrett490 02-28-2016 02:06 PM
Yea I think mine are two orange colored. Then again I think I'm just more of a factory look type of guy. Prolly going back to original and also plan on ditching the aftermarket RUF style valance for the original.
Spumato 02-28-2016 02:17 PM
Does the valance serve a purpose? I mean is the a central mounted oil cooler sitting behind the inlets. If not, it does seem a bit silly to have that over the original valance. The color of the wheels would be fine, IMO, if you car was a different color. Not sure how well they compliment black. They look similar in color style to what I have seen on some S/T wheels.
garrett490 02-28-2016 02:56 PM
No oil cooler. This valance replaces the factory one; it's not installed over it. And I know it's hard to tell but my car is shwarz metallic which has a dark bronze flake that is more apparent in sunlight
Jp-oh 02-28-2016 03:09 PM
Did you do the wheels yorself and if yes what did you use. Ive been mulling a copper/bronze for my wheels.
garrett490 02-28-2016 03:16 PM
Plasti dipped them black 2 years ago...sprayed copper "metalicizer" plasti dip over the black yesterday. This is a common recipe with several examples online.
Jp-oh 02-28-2016 03:30 PM
Do the gold-bronze metalizeres ahve to go over plasti dip or can they be used on other surfaces?
Justin@Athens 02-28-2016 04:27 PM
i like it
HarryD 02-28-2016 05:56 PM
This is how Copper is done:
http://r.ddmcdn.com/s_f/o_1/cx_0/cy_...201_135507.jpg
Thanks to Dave Kindig.
Nate2046 02-28-2016 06:07 PM
I think the copper looks amazing in the pics, but like JP-oh said you need some contrast. Before you ditch the whole thing, why not try the background 'webs' in black with the spokes and lip left in the copper color?
stormcrow 02-28-2016 07:52 PM
I think if you had the Porsche badge on the center caps that would really set them off.
Jonny H 02-28-2016 10:55 PM
Copper colour looks great. I tried the same but left the rims silver.
How did you prep the wheels? Mine are polished and the plastidip started to lift around the wheel lugs, bubbled and came off. How did you go round the wheel lugs?
garrett490 02-29-2016 03:28 AM
No real prep other than cleaning before spraying the copper metalizer dip onto the previously black dipped wheels. I took the wheels off he car to do this. Used 2 cans of copper.
I do have the porsche badge on the center but it's copper colored.
Not sure if the metalicizer has to be sprayed on a previously dipped surface or not.
garrett490 02-29-2016 03:32 AM
Just washed the wheelers prior to spraying the copper. Took the lugs and painted them black with rustoleum. Poked 20 nails into a pice of cardboard then set the legs over the nails so I could paint all sides of them.
kach22i 02-29-2016 04:43 AM
A darker bronze might be a more traditional throw back to Porsche 917 Wheels and match your colors better, but the extra life and spunk of this more forward copper color works well enough.
Let them get a little dirty from some brake dust, and they will be perfect.
universeman 02-29-2016 05:22 AM
Some of this will help them stand out also http://www.meguiars.com/en/automotive/products/g13919-hot-shine-tire-foam/
jbuggyus1 02-29-2016 06:35 AM
Just painted mine last week and just installed back on car.http://forums.pelicanparts.com/uploa...1456760083.jpg
jbuggyus1 02-29-2016 06:42 AM
The color is something I mixed up , a tad of gold with some silver Auto paint I had left over. Color is very similar to the plastic coat vintage gold.http://forums.pelicanparts.com/uploa...1456760531.jpg
