-   -   What is this gooey stuff and what to do about it? (http://forums.pelicanparts.com/porsche-911-technical-forum/904184-what-gooey-stuff-what-do-about.html)
kristan 02-28-2016 02:59 PM
A few years back I had some rust repair done in the front trunk.
The guy from the body shop applied some black gooey stuff over the welding seams.
After more than 5 years or so that stuff is still sticky. Did he forget to paint over it?
What should I do with this, remove it or paint primer over it?
Thanks.
http://forums.pelicanparts.com/uploa...1456700318.jpg
stormcrow 02-28-2016 07:20 PM
Clean it up with paint thinner and if it needs to be painted go ahead and do it.
jkuntze 02-28-2016 07:40 PM
gooey stuff
its seam sealer leave it alone
kristan 02-28-2016 08:04 PM
Is it okay to paint over this stuff so that not everything sticks to it?
stormcrow 02-28-2016 08:38 PM
Unless you have a big hole there it isn't needed. If there is a seam there you can get some polybutal calk and paint over it. I don't have any of that gooey in that spot on my car. Somebody may be hiding something and the only way to find out is to remove it.
timmy2 02-28-2016 11:50 PM
A few old time somewhat shady body men would use roofing tar as a sealer on rusted areas when I lived in salted road country....
