Rubber Hood Strap Question
I am about to install the RS rubber hood straps on my car and have noticed in photos that they are installed in different orientations at times. There are nubs that are located in the middle of the straps that are sometimes facing outward and sometimes facing inward.
What is the proper way to install them?
Below is a couple of pictures I acquired for reference and are not my cars. Tough to see but notice the difference in orientation.
Thanks for your help.
Lou
Old 01-03-2016, 01:42 PM
RETIRED
Joe Bob's Avatar
Nubs in.....those are upside down BTW.
2012 ML350 3.0 Turbo Diesel
Old 01-03-2016, 04:09 PM
Cars and Cappuccino
tdw28210's Avatar
This Brumos car is a real (I think). Looks like the screws for the lower piece go under the rubber trim at the top of the bumper. Never seen them installed with the t-pull facing down. However, they DO get installed with the "T" pulling down in the rear.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 01-04-2016, 06:02 AM
Not really, at least how they were installed by Porsche. I can think of just one car, the Gerard Larrousse 911R, that had a single front strap installed the other way.
JR
Old 01-04-2016, 06:32 AM
what's the consensus on fastener? pop rivet?
Old 01-04-2016, 06:42 AM
Pop rivets are not very strong. If you are going to use a rivet, use one with a much higher strength. Steel, captures the mandrel, etc...
If installing these in a fiberglass hood, put a decent-sized backing plate on the back side.
JR
Old 01-04-2016, 07:00 AM
Cars and Cappuccino
tdw28210's Avatar
JR
I agree, use a backing plate and stainless screws and perhaps counter sunk stainless t-nuts. I am not crazy about the rigidity of the top of my glass front bumper to begin with, so it is getting some steel to beef it up.
Old 01-04-2016, 07:05 AM
Interesting, I thought riveting was the way to go. I do have a steel bumper and steel hood, am I better off with screws?
Even though Joe Bob thinks the rubber straps are upside down in the photos and no one else agrees, we all agree "nubs" go facing inward, correct?
Thanks.
Lou
Old 01-04-2016, 08:16 AM
Rivets are okay, if you use the right ones. They come in a bunch of different types, materials, sizes, etc. There are some that are quite strong, but they also must be sized and installed correctly.
You specified pop rivets. That can mean two things. POP brand rivets, or generic hardware store rivets, which is how most people use the term. What you might find in your hardware store is a 1/8" aluminum rivet that does not retain it's mandrel and has very low strength.
Do a search on rivets and learn a little about them. There's a ton of info out there and it's quicker to do a search than for me to type the rest of the afternoon. Then, buy something appropriate for what you are going to do, size them correctly and install them with a good tool. You should be fine.
EDIT: If you are planning to install the rubber straps on your SC pictured in your garage, you have 964 bumpers on that car, which will present a challenge. If the parts are factory, you have a plastic bumper over a metal bumper support and there is probably a space between the two parts. Rivets won't be a good solution there, you'll want to use bolts, plus some spacers between the bumper skin support, if there is any space between them.
JR
Old 01-04-2016, 08:37 AM
javadog,
Thanks for the information.
I have backdated my car recently and the pictures in my garage do not reflect that yet. This is a picture of my car as of last week.
Lou
Old 01-04-2016, 08:54 AM
In that case, rivets would be fine, as long as you pick the right ones and install them correctly.
JR
Old 01-04-2016, 08:59 AM
Recreational User
porschenut's Avatar
The nubs go INSIDE. Always.
And use rivets to attach them. On a FG bumper (as I did mine), put a thin metal backing plate on the underside of the bumper to sandwich the fiberglass, which is weak and can crush and splinter over time due to stress.
Old 01-04-2016, 09:03 AM
Cars and Cappuccino
tdw28210's Avatar
Check these out. Threaded rivets.
Rivet Nuts / Threaded Inserts | Rivets In Stock - Rivets & Rivet Tools
Old 01-04-2016, 09:12 AM
Finally got the rubber hood straps mounted. Thanks for all the help.
Lou
Old 03-23-2016, 05:20 PM
mikl911
Looks great will be putting them on the 67 soon. RS clone to R clone begins. It's a sickness!
Mikl911
1967 911 RS clone owned since 1992
1978 911 SC/R Sinister hot rod
1937 Ford Slant back Hot Rod
2000 M5 ECU upgraded (sold)
Old 03-29-2016, 11:55 AM
Thanks! It was very simple to put them on once I got the nerve to drill the holes in the hood and bumper.
I agree, it is a sickness.
Lou
Old 03-29-2016, 12:43 PM
Administrator
Luccia at Pelican Parts's Avatar
Looking good Lou! Great job on the install.
Old 03-29-2016, 01:10 PM
Thanks Luccia
Lou
Old 03-29-2016, 03:23 PM
