-   -   Possible Heat Delete - Pros and Cons? (http://forums.pelicanparts.com/porsche-911-technical-forum/904850-possible-heat-delete-pros-cons.html)
manbridge 74 03-05-2016 07:00 AM
Originally Posted by carwash (Post 9024305)
Actually all I want is defrost.... It's all i care about. I wish i could do that easily without heat exchangers, duct work, etc.... i just want warm air on the windshield, controlled with an on/off lever... impossible i guess.
There are anti-fog products available. They work well if applied correctly.
carwash 03-05-2016 07:02 AM
Fog-X it is.... i'm deleting the heating system. If i get cold, I'll add in some heated seats, lol.
javadog 03-05-2016 07:04 AM
Getting heat without heat exchangers and ductwork is impossible. Where will the heated air come from? Magic?
You can have a system that is like this:
Ducts from cooling fan shroud to heat exchangers.
Ducts from heat exchangers to flapper valves.
Ducts from flapper valves to body.
Ducts from body to outlets in dash.
One or two levers (your choice) to control it.
Simple, light weight. The heat exchangers don't weigh much more than the headers you could use in their place and the rest of it weighs about as much as a gallon of gas.
I think you are making this harder than you have to.
JR
carwash 03-05-2016 07:06 AM
I guess I'm just looking for simple. I don't need heat, just want defrost. I will see what kind of shape all the parts are in and go from there.
How limited are my exhaust options when using heat exchangers?
and yes, i know it's not possible to get heat without exchangers, it was a rhetorical question, sorry.
javadog 03-05-2016 07:09 AM
Not limited at all. I can think of at least a dozen mufflers you could use, that are off the shelf.
A small 911 six can use all of them.
JR
RSBob 03-05-2016 07:20 AM
I have had two early cars and their plumbing is completely different than the IB cars which I currently drive. Early cars have no engine compartment blower or footwell blowers. You have a passive system which takes hot air from the heat exchangers which is driven by the engine fan. IB car owners call this backdated heat.
Unfortunately for you, removing the heat exchangers will remove any possibility of heat to your windshield. And unless you live in the U.S. SOUTHWEST or Africa you will need it to defrost the windshield. Anti-fog sprays just don't work that well either. But the good news is that you already have the lightest heating system made. If I were you, I would put a sport exhaust on it and be happy.
Canada Kev 03-05-2016 07:35 AM
Originally Posted by Canada Kev (Post 9023986)
With a complete heat delete, you should still be able to have a rudimentary defrost system with just FRESH air and no heat. It's better than a poke in the eye, but not as good as if the air was heated. However, if it's a bit chilly and raining, you will likely experience a fogged windshield.
Originally Posted by carwash (Post 9024202)
Please explain what I retain in the system to make this work.
First you need to do some research to learn how the HVAC system works in your car. Fresh air ventilation is a completely different system than the heating system.
Deleting your heat by removing the heat exchangers isn't that great of an idea for a street car in my opinion, for only a small weight advantage. Heat is required to have decent defog.
Without heat, your defogging will be very handicapped. However, the fresh air for the cabin will, albeit just using airflow from the outside boosted with the fan, provide a small amount of defogging. Unless it's raining out. Then you're just going to be blowing more moist air on the windshield.
3literpwr 03-05-2016 07:46 AM
Anyone have the part numbers needed for this?
javadog 03-05-2016 07:54 AM
For what?
911tracker85 03-05-2016 08:30 AM
we need to talk.....
family commitments this weekend or I'd suggest you drop by.
PS. and my friend will be selling that 915 tranny, so another topic I forgot to mention yesterday.
http://forums.pelicanparts.com/uploa...1457191236.jpg
Ferrino 03-05-2016 09:07 AM
If you want to retain heat purely for defogging and simultaneously clean up under the hood, you can do this and send heat directly from the rockers to the dash vents. Just remember to block off the fresh-air vent to stop ingress of water. You obviously lose fresh air supply this way.
http://forums.pelicanparts.com/uploa...1296425145.jpg
NYNick 03-05-2016 09:46 AM
Guess I'm a pansy. I like to drive the car when it's not perfect out. It gets cold in the car and the windshield needs defrosting. I also think you limit the marketability of the car thereafter, but I'm guessing you're not concerned with such.
I'd like to think I don't need heat and could lighten the car some more, but it sure is nice to have. In my neck of the woods, it's the A/C I/we don't need.
Rodsrsr 03-05-2016 10:14 AM
Just curious, where are those hoses connecting too? I know the top end is going to the defrost, but the bottom ends?
carwash 03-05-2016 01:35 PM
I think this kind of system might be perfect. air directly from engine to defrost vents, controllable by the lever at the parking brake?
javadog 03-05-2016 01:41 PM
Yes. Re-read post 23....
carwash 03-05-2016 02:06 PM
Giddy up, we're in business.
Canada Kev 03-05-2016 03:37 PM
I don't get what you'd be gaining from this. Except losing cabin heat and fresh air. You'd still need everything that's already on the car except a fresh air fan in the frunk, maybe three pounds.
javadog 03-05-2016 03:52 PM
What you don't get is his system is nothing like yours. He doesn't need to lose heat in the cabin with this arrangement. Fresh air, crack a window...
JR
JJ 911SC 03-05-2016 03:53 PM
Originally Posted by Tidybuoy (Post 9023952)
Backdated Heat - 2 hoses and that is it...
Sure is...
http://forums.pelicanparts.com/uploa...1457221971.jpg
