-   -   Could the cold be to blame? (http://forums.pelicanparts.com/porsche-911-technical-forum/90511-could-cold-blame.html)
87turbolook911 12-11-2002 11:08 AM
1 Attachment(s)
Haven't driven my car since Nov. 27 because it's been cold and snowy here in DC. Temps have been as low as single digits. The car never leaked oil before. Yesterday I noticed a small streak of engine oil on the garage floor. :( Maybe a tablespoon worth of oil.
I got on my knees to see where it's coming from and it seems to be from the very center of the bottom of the engine.
Could this be because of the cold and not driving it? Should I be worried?
:confused:
Early_S_Man 12-11-2002 11:14 AM
It could indeed be due to the cold extremes ... shrinkage, etc. Oil return tube seals come to mind as a possibility, though I doubt that you will have a long-term leak problem once the car is driven again and the engine is heat-cycled a few times.
Jbabic 12-11-2002 12:12 PM
You have MAJOR ENGINE DAMAGE and should sell you car to me. to avoide such high repair costs.
just kidding.....sort of....when you want to see, let me know.
Jerry 513-218-1296
87turbolook911 12-11-2002 07:53 PM
bump
bump
Joeaksa 12-11-2002 08:04 PM
Oil return tubes... sell the car to me and I will be happy to shoulder the burden...
Joe
RickC 12-12-2002 08:06 AM
My 87 does the same thing while it sits in an unheated, detached garage. Tight as a drum all spring, summer and fall, then a small leak coming from the oil return tubes, winding down to the center of the engine case, and dropping to the floor.
Freaked me out when I first bought the car, now I don't worry as it stops as soon as the air warms up. Every spring I power wash the underside area at a do-it-yourself car wash. No leaks during the other 3 seasons.
I worried so much that I actually ordered the newer, two-piece oil return tubes from Pparts one spring (car's are original one-piece). Returned them once the leak stopped - thanks Wayne! You should be OK.:) :)
87turbolook911 12-12-2002 08:15 AM
Thanks all...
for putting my mind at ease. Can't wait till the road salt disappears so that I can drive it again.
"Everything I own is for sale, just need to get the right offer" :)
Jbabic 12-12-2002 08:42 AM
How much for your soul.......the devil!!
87turbolook911 12-12-2002 08:44 AM
YIKES.....
:eek:
