G50 conversion help
Hi
I am planning a G50 conversion in my 81 SC. I need to know if a 964 or 993 pedal assembly will fit into my 81?
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 12-11-2002, 03:16 PM
Not without extensive modification and even then I do not know if it will work. I was sent a 964 G50 pedal assembly instead of a 87-89 pedal assembly and they are completely different. The 87-89 box is a direct replacement, the 964 box is not.
Garrick S. Lew
600 Townsend Street, Ste 329E
San Francisco, CA 94103
gsl@defendergroup.com
Old 12-12-2002, 01:15 AM
Thanks Garrick that is what I thought
Dean
Old 12-12-2002, 05:22 AM
Mikkel
Guest
Posts: n/a
Question
So how different are 87-89 G50 gearboxes and 964 G50 gearboxes?
Old 12-12-2002, 06:04 AM
964 G50 gearboxes have a "long nose" and 87-89 G50's have a short nose. To fit a 87-89 short nose G50 to an 86 or earlier 911 or 930 the bell housing and main shaft must be shortened by approx 1 inch. A 964 G50 will not work unless you replace the long nose piece with an 87-89 short nose and shorten the bell housing and mainshaft approprietely.
Garrick S. Lew
Old 12-12-2002, 07:42 AM
