Random horn blowing
Hello. I'm having a problem with the horn on my '69 912. It sounds randomly without my input. I can't make it happen although it seems to occur after a sharp turn and almost always while I'm in motion. The steering wheel is a Moto Lita with a flush horn button. The button isn't depressing on its own--the spring has good resistance. My guess is a faulty horn contact pin. Am I on the right track? Thank you.
Old 03-08-2016, 01:46 PM
ROW '78 911 Targa
timmy2's Avatar
Check the wire to the contact isn't abraded (insulation worn) and making contact to ground.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-08-2016, 02:00 PM
look at the wires and clean the connectors..
Scott
1979 930 - Black on Black and in the woods
"My third child that will cost more in the long run" :shock:
Old 03-08-2016, 03:32 PM
Guardsred911's Avatar
Check the steering wheel. That's the issue. Either a bent or dirty contact will do this.
Old 03-08-2016, 03:42 PM
Michael T's Avatar
Sounds like a wire that needs insulating.
1987 928 S4 - Black
2014 C4s 991 - Agate Grey
2014 Cayenne - Mahogany metallic
Old 03-08-2016, 05:23 PM
Been here a while
There's a rubber donut of the back of the horn butterfly. When it gets hard/brittle the horn will blow intermittently
Found a period correct hotrod motor, but still looking for 1972 911t motor, 6121622
Old 03-08-2016, 06:59 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I know how that feels - mine went off on a permanent blare in dense LA stopped traffic on the 405. Can you imagine the looks I was drawing as I was frantically trying to get over from the fifth lane to the side to pull the relay. OMG.
'74 Targa 3.6 (not stock ) - '01 C4 (almost stock) - '00 ML430 (stock)
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2 - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 03-08-2016, 07:50 PM
My 914 did the same thing. It would randomly honk as I hit bumps or turned. It decided to start blaring right after I pulled up behind two tough looking Harley riders.
42 Year member of the Porsche Club of America
Old 03-09-2016, 05:44 AM
Hi again. I looked everything over and couldn't find anything obvious. I took took the car out yesterday and the horn started blowing again, now very frequently. I was able to pull out the horn button and remove the single wire from the connector. The wire was not grounded on anything, yet the horn was still blowing. So somehow, the horn circuit is energized and grounded without the horn button. Does this sound like a bad relay?
Old 03-13-2016, 07:59 AM
Your car has a case of automotive Tourette's syndrome.
1986 911 3.2 Cabriolet
"We all have a desire to create something that will show we were here. " Ferry Porsche
Old 03-14-2016, 05:00 PM
ROW '78 911 Targa
timmy2's Avatar
In/ below/behind the fuse panel area, there is a single connector for the brown/white wires from the dash wiring to the relay wire, maybe the problem is there.
Also check the wiring from the 6 pin connector to the steering column.
Dennis
Old 03-14-2016, 07:49 PM
