Jase77's Avatar
Brake Caliper Rebuild.....
Hi Pelicans,
I am currently rebuilding the rear brake calipers on my 77 911S. I have just received a rebuild kit from ATE which comprises of the rubber seal, the metal clip ring and an extra rubber ring. When I dismantled the calipers this extra rubber ring was not present. Anybody know what it is for? Is it for another make of Caliper Piston perhaps? I have the steel calipers which I believe are the 'M' type. Here are some photos...
As they came out.
Old seal at the top and the new one with the extra rubber ring at the bottom.
Any info and suggestions would be appreciated.
Cheers.
1994 968CS
1977 911S
1969 MGB GT
1958 Norton Dominator
Old 03-13-2016, 09:43 AM
The Bavarian
That is the seal in the caliper bore that seals the piston to the bore. You probably haven't removed it from the old caliper yet!?
- Manfred
'80 911 SC Targa black/black
Old 03-13-2016, 09:49 AM
It is the piston seal that sets in a groove in the cylinder bore. Clean your bores and you will find the old ones to R&R.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 03-13-2016, 09:51 AM
Jase77's Avatar
Thanks guys. VERY quick responses, so thank you very much. I just went back into the garage and had a closer look and you are spot on!
Cheers and Vielen Dank!
1994 968CS
1977 911S
1969 MGB GT
Old 03-13-2016, 10:00 AM
More Likeable IRL
juanbenae's Avatar
the dental pick tool was the perfect choice for that job...
Old 03-13-2016, 10:23 AM
