-   -   Mid Year Alignment Specs (http://forums.pelicanparts.com/porsche-911-technical-forum/905809-mid-year-alignment-specs.html)
sketchers356 03-11-2016 05:45 PM
Hi All,
I have tried to do some searching, but I haven't been able to find any information on this using the keywords that I have. Sorry if this has been discussed to death.
I have a '75 Targa S with 15x7 rims. Going to get new tires this season, thinking 205/60R15.
Anyway, I also want to have the car lowered and aligned. Car is primarily street driven. What specs work best with lowering the car and with modern rubber? I plan on having an Elephant Camber Strut Brace installed as well.
Thanks!!!!
stlrj 03-12-2016 03:52 AM
Alignment specs will do you no good since you will be lowering your car and that will dictate how far off spec your car will result.
But just for fun, here is what the Spec Book says your alignment should be:
Front Camber ........+30'+/- 10'
Toe..........................0'
Rear Camber............0'+/-10'
Toe...........................10'+/-10' each wheel
Cheers,
Joe
